Halo Replacement
Old Apr 26, 2007 | 06:15 AM
JPizzle's Avatar
Halo Replacement
Has anybody replaced their halo? I just had one not to light up.
MLurkey, I think that you said you had some 3 MM LED's (considering that's what the halos are)... Has anybody installed new halo's? How do you do it?
Old Apr 26, 2007 | 06:34 AM
BOOSSTED 06's Avatar
to install an entirely new halo im assuming you would have to crack open the headlight. Just replace the led's its not hard, you just need some wire, leds and resistors.
Old Apr 26, 2007 | 09:39 PM
JPizzle's Avatar
I see. I see. How would you get to the halo?
Old Apr 27, 2007 | 02:34 AM
HunterKiller89's Avatar
i have the same ssue and i emailed CA about it...n this is the response kenny sent
The leds are come out from the light . Just check that the leads for the leds are not grounding out as the design of the light and adjustment of the light do end up hitting the leds . Make sure the led leads are not grounding out . You can remove the led from that halo and test it outside the light . IF it is blown send it back to us and we can send you a replacement when we receive it back
Thank you ,
Kenny
just ounds like theres some wire movement inside the halo housing...but i have yet to get my lights out of my car since i got em in
Old Apr 27, 2007 | 02:49 AM
Omega_5's Avatar
Ditch those POS LED halos that they give you, and swap in a few CCFL rings from a Logisys computer fan... looks 100 times better, lasts longer, and has way better durability.... plus they work with HID headlights.... (believe me, I know!)
I should keep reposting this link every week... it seems that people keep missing it....
https://www.cobaltss.net/forums/appearance-48/halo-ring-replacement-50387/
Here's what I said in the link!
Originally Posted by Omega_5
Logisys Cold Cathode rings!
http://www.logisyscomputer.com/views...BL&DID=COOLDEV
I know it sounds crazy, but the R1 guys have been making their own halos/angel-eyes with this method for years!
Best of all, they are glass... they don't melt!
Here is a link the newest R1 forum how-to
http://www.r1-forum.com/forums/showthread.php?t=187404
Old Apr 30, 2007 | 10:08 AM
JPizzle's Avatar
I already read that Omega, but it doesn't say HOW to get to the halo. Whether I have to take apart the headlight & reseal it with silicone... I know the LED's just pop right out & right back in. I just don't know how to get to the halos.
Old Apr 30, 2007 | 10:24 AM
5150studios's Avatar
If you want to take out the actual HALO ring, YES you need to seperate the housings. Once the housings are apart you can just peel away the silicone on the BACK of the HALO housing and it will fall right off. There are 3 parts to the headlight. Clear front, main body that holds ALL LEDS and HALOs, and then the back that holds the projector and high beam
If you want to just replace the bulbs they come out the bottom of the housing VIA the rubber stoppers.
Hope this helps
Old Apr 30, 2007 | 02:44 PM
JPizzle's Avatar
It does. Thanks man! Now I just have to do it...
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
