HELP, What to use for painted headlights....?
Old Jul 23, 2005 | 03:10 PM
johnkb8's Avatar
Got my extra pair of headlights, i just want the BEST stuff to paint them black, and the BEST stuff to seal them back up so i wont have any problems with the seal down the road, dont care on price just want the right stuff, and where to get it, and should i use flat black paint or gloss black, i seen gloss black down on rsx and looks good, not really any gloss at all, just looked really good, any help here....... thanks
Old Jul 23, 2005 | 04:07 PM
DC52NV's Avatar
i used flat back to do mine. they look sweet. just make sure you get high temp paint.
Old Jul 23, 2005 | 04:15 PM
johnkb8's Avatar
ok and now on what to use on sealing the lights back up, thanks........
Old Jul 23, 2005 | 05:17 PM
tiny's Avatar
use krylon fusion, or plasti-cote
any plastic paint will work, but fusion is the best
and to seal it back up, the old glue will work, for somereason the guy that did it first said to remove
but its heat activated, so you can re-use it
tiny's Avatar
no need to, plastic paint can withstand 175 degrees, i doubt the headlight housing would ever get that hot, except when in the oven
Old Jul 23, 2005 | 05:21 PM
DC52NV's Avatar
oh ok, i just took extra precaution cuz i don't know how hot it gets in there w/ the lights on and the brights turned on as well.
Old Jul 23, 2005 | 05:36 PM
johnkb8's Avatar
i still want to get something else on there to seal it up, so they are perfect
Old Jul 23, 2005 | 06:23 PM
randy1kleeman's Avatar
tiny, question have you ever put your hand on a flashlight and held it there for a long period of time? well if you would have...you would kow that it gets around 200+ degrees. i think that the high beam and low beam on a car running with its light on for a long period of time would melt that paint. go with the paint that is a little more expensive...you said you wanted it done right.
Old Jul 23, 2005 | 09:47 PM
tiny's Avatar
put ur hand on the outside of the flashlight? is it hot??
if you paint the reflective part, yes, but the bezel can withstand the heat
trust me, i have a lot of friends who used the same paint i just said, and it was fine
i also work in a paint department, so i know a lot about paint
Old Jul 24, 2005 | 01:54 AM
Mercury's Avatar
To those who have painted black, did you primer and sand the area before paint?
Old Jul 24, 2005 | 02:09 AM
DC52NV's Avatar
sanded it a lil but not much.
Old Jul 24, 2005 | 10:17 AM
Mercury's Avatar
what grit paper did you use DC52NV?
Old Jul 24, 2005 | 12:50 PM
tiny's Avatar
you should use 300 girt, or something finer
even a liquid deglosser will work
Old Jul 24, 2005 | 02:25 PM
DC52NV's Avatar
use the finest sandpaper you can find. i think i used like 300 grit.
Old Aug 21, 2005 | 01:41 AM
CobaltSS422's Avatar
Now what about for someone who is looking at getting HIDS and painting the inner housing? Obviously use the high temp paint but how hot do the HIDS get? if anyone knows
Old Aug 21, 2005 | 01:44 AM
Mercury's Avatar
Visit www.hidplanet.com
Consider a retrofit
Hids run at lower temperatures than halogen.
Old Jan 23, 2006 | 05:46 PM
05REDROCKET's Avatar
i got mine done professionally and you dont need high temp paint as long as it gets a good coat of clear
Old Jan 23, 2006 | 05:47 PM
and i would use at least 800 grit wetsand paper prefabbly 1000 grit after the first coat of colour
chefhhr
Oct 26, 2015 10:36 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
camaromanss1992
Oct 1, 2015 10:51 PM
riceburner
Sep 26, 2015 12:57 AM
