HELP, What to use for painted headlights....?
Got my extra pair of headlights, i just want the BEST stuff to paint them black, and the BEST stuff to seal them back up so i wont have any problems with the seal down the road, dont care on price just want the right stuff, and where to get it, and should i use flat black paint or gloss black, i seen gloss black down on rsx and looks good, not really any gloss at all, just looked really good, any help here....... thanks
use krylon fusion, or plasti-cote
any plastic paint will work, but fusion is the best
and to seal it back up, the old glue will work, for somereason the guy that did it first said to remove
but its heat activated, so you can re-use it
Originally Posted by DC52NV
i used flat back to do mine. they look sweet. just make sure you get high temp paint.
no need to, plastic paint can withstand 175 degrees, i doubt the headlight housing would ever get that hot, except when in the oven
tiny, question have you ever put your hand on a flashlight and held it there for a long period of time? well if you would have...you would kow that it gets around 200+ degrees. i think that the high beam and low beam on a car running with its light on for a long period of time would melt that paint. go with the paint that is a little more expensive...you said you wanted it done right.
put ur hand on the outside of the flashlight? is it hot??
if you paint the reflective part, yes, but the bezel can withstand the heat
trust me, i have a lot of friends who used the same paint i just said, and it was fine
i also work in a paint department, so i know a lot about paint
Originally Posted by CobaltSS422
Now what about for someone who is looking at getting HIDS and painting the inner housing? Obviously use the high temp paint but how hot do the HIDS get? if anyone knows
Consider a retrofit
Hids run at lower temperatures than halogen.
camaromanss1992
Oct 1, 2015 10:51 PM
