HID / Projector kit - daytime running lights question.
I'm looking in to buying the projector light assemblies and a set of HID bulbs. I have one question though. Will my daytime running light module trigger the HIDs? I believe it is just a lower current to the bulbs in stock form and driving around in the daytime with HID's blazing is a bit cheezy and I'd imagine would shorted bulb life. Is there any workaround for this such as setting it up so the marker lights come on instead of the daytime running lights when my car is on? I'd imagine I'd need a couple of relays but not sure how tapping into the wiring is going to effect the lighting control and I don't want to fry something. I've looked at the wiring diagram but I'm at a loss for ideas on how to resolve this.
My optimal situation, as I stated earlier, would be to have the markers/signals come on instead of the actual headlights - possibly somehow wire the low voltage daytime running light power to the smaller filament in the markers/signals and just throw a resister or something on there in its place to prevent it from telling me I have burned out bulbs.
Anyone done this or have any advice? Thanks!
d.
d.
if you will be using projectors....then theres a nice little switch in the car to turn on the Halos and LEDs without turning on your low/hi beam lights....turn the lighting...thingy...from auto up one click....there are 4 options that do the following in order
Headlights on
Running Lights on (halos, LEDs, orange bulb)
Auto
Off
Headlights on
Auto
Off
so did i. i didn't even touch the headlight wiring except for pluggin the low and hi's to the 9007 harness or wutever. but yea reign answered my question already.
Original Hayden Fanatic
its cuz with the daytime running lamps, the low beams are on but they are dimmer then when the headlights are on at night. i was worried if the HIDs would be on all day whether at regular light output or dimmer during the day, they would mess up.
It depends on what year car you have. For the 2005/2006 your ambers will still go on. For the 2007 with low voltage DRL, I do not know. It depends on how the ballasts react to the lower voltage. There is an easy solution however, since the DRL have their own fuse, you can simply remove it.
FYI: please don't install HID without projectors, and don't get anything above 8000K
as the color temp goes up, output goes down. stick to white, be safe, and get the most the projectors have to offer
WhineSSbaby
Sep 1, 2020 12:39 PM
Sean Cummings
Mar 9, 2018 12:26 AM
