L.E.D. Talilights
Old Dec 5, 2008 | 02:08 PM
  #51
knoxbox's Avatar
quote pictures?
Old Dec 5, 2008 | 03:33 PM
  #52
AuhsoJ007's Avatar
dear Spun,
Thanks. I wanted to know what the bemuda black IPCW lights looked like. I have a red 05 ss s/c. do you think those would look good on my car?
Old Dec 6, 2008 | 04:22 PM
  #53
Spun's Avatar
Well I bought them to match the back projectors I have but I think they look good either way so yes I think they would look good on your car
Old Dec 6, 2008 | 08:23 PM
  #54
Cobalt08LS's Avatar
question. so when you install the ipcw tail lights and have the car on and in park
both the outer led's and the inner led's are on right? also when im driving at night both the outer and inner led's will be lit up.
correct?
Old Dec 6, 2008 | 11:57 PM
  #55
AuhsoJ007's Avatar
correct?
for your information I don't even have them but I've been doing so much research I'm 99% sure..... Yes they are both lit up. the inner and the outer at the same time constantly. They work just as your regular stock brakes would just with inner and outer.
The only thing that i'm not 99 on is the question. Do you have to wire the inner lights/piggy back them for power off of the outer lights?
Old Dec 7, 2008 | 01:23 AM
  #56
Cobalt08LS's Avatar
idk about that
i believe there plug and play?
but how would the power get to the iner lights if there on all the time?
like ive seen videos when the car is turned on and all the lights are on
and i guess they get brighter when the brakes are on?
Old Dec 7, 2008 | 10:57 AM
  #57
Red07SSNA's Avatar
When you install the IPCW LED taillights they come with the wiring to the inner lights. You have to run the wiring from the outer tailights to the original wiring loom and bring them up into the trunk lid and connect them to the inner lights. Your original wiring is used to connect the outer lights -- you just take out the bulb and the outer light connecter goes into the bulb socket. It is fairly easy. the original back up light bulbs/sockets fit into the center of the inner lights like factory.
All 4 lights are on when the headllights are on, all 4 light up when you brake; when you use the turn signal both lights on the side you select blink, and when you use the flashers all 4 lights flash.
Old Dec 7, 2008 | 12:05 PM
  #58
Cobalt08LS's Avatar
hmm. sounds sorta confusing...
does it come with instructions or something?
Old Dec 7, 2008 | 02:37 PM
  #59
Red07SSNA's Avatar
Instructions are not very good...best if you have a little basic car knowledge...but not difficult.
Old Dec 7, 2008 | 02:41 PM
  #60
Cobalt08LS's Avatar
hmm so the outer ones are just plug and play and than the inner ones you have to wire to the outer?
is there a diy on here any where?
Old Dec 7, 2008 | 04:14 PM
  #61
TheCaptain's Avatar
Its extremely simple guys. You can't **** it up. The outers plug into your lighting harness, and the lights come with the wiring (male/female connectors) to tie the outers to the inners. No electrical know how is really required. Unplug, and plug in.
Here's some pics after install, and a vid on what the lights look like.
https://www.cobaltss.net/forums/appearance-48/led-tails-%2A56k-maybe%2A-93397/
Old Dec 7, 2008 | 04:21 PM
  #62
Cobalt08LS's Avatar
alright i think i understand how do do it
you plug and play them like normal
than theres a conector wire from the outer you connect one end to that to the outer than run the other end like you have yours up the trunk to the inner and plug that other end into the wire coming out of the inner light
correct?
yea i saw your post yesterday and was trying to find it today
these tail lights look sick and i deff want to get them
idc how the inners stick out a little bit. they stick out to show the black around them which i think is cool
i might be doing the LED third brake light too
trying to get these tails for the holidays
hopefully i will
that would be awesome if i do
i see you have the led third brake light too. how exactly do you hook the one up from modern performance
i want to get it
Old Dec 7, 2008 | 04:35 PM
  #63
TheCaptain's Avatar
You are correct with your first statement, and the CHMSL is easy too. Take it apart, pull the bulbs out of it, plug MPCs plugs into where the outer bulbs were, pull the adhesive off the strip, and stick it to the parts of the CHMSL that stick out, and reassemble.
Old Dec 7, 2008 | 04:37 PM
  #64
Black SS/SC 06's Avatar
I got the ones from modern performance and havent had any problems.
Old Dec 7, 2008 | 06:36 PM
  #65
Cobalt08LS's Avatar
thats for the 3rd brake light correct sorry i saw the chmsl in here before and dont know what it stands for
yeah i think i can do the tails myself with the help of a friend
Old Dec 8, 2008 | 10:13 AM
  #66
DFZ24's Avatar
the 3rd brake light is simple once you put apart the section where the lights bulbs are everything comes clear how to do it, i was kind confuse how to do it too. but when i put apart everything i could see how to put it on. i got some pics of how i did mine (mine are the led light from the impala) if you wan i can post them.
you dont even have to take off the entire linner inside, i use it as a table lol.
Old Dec 8, 2008 | 01:56 PM
  #67
Cobalt08LS's Avatar
welll i mean if i see everything ill know how to do it right
just take out the old one put the new one in
i might order it today
do you just take off the 2 bolts to the silver plate and unplug it
does anyone have a detailed diy for the modern performance one?
Old Dec 8, 2008 | 07:21 PM
  #68
TheCaptain's Avatar
Yes, two bolts, one plug, and there is some soft clips i believe as well.
CHMSL = Centre High Mount Stop Lamp (3rd Brake light)
Old Dec 8, 2008 | 09:14 PM
  #69
Cobalt08LS's Avatar
gotcha. so you take off those two bolts than the sillver piece comes off and you see the wire and just unplug it
do you have to pull the light off the board like is it glued on? o does it just clip in?
Old Dec 8, 2008 | 11:27 PM
  #70
Red07SSNA's Avatar
Contact Modern Performance and ask them if they would send you the instructions on how to install them.
From their site:
Installation is simple, theres no wiring to cut, no wiring to solder. You merely seperate the lense from the reflector backing of the factory third brake light, and affix this led board into the stock third brake light with industrial grade double sided tape (provided). It then plugs into your factory wiring like a regular bulb would. Total installation time should not be any longer than 1.5 hours at most, with only a box cutter, or knife, socket set needed.
Old Dec 9, 2008 | 01:56 PM
  #71
Cobalt08LS's Avatar
alright
thanks
Old Dec 17, 2008 | 02:55 AM
  #72
d2k_01's Avatar
Anybody have some really interesting/differnt custom light set-ups? I've seen one or two sets with lights added to the center. Anything else though? I'm looking for inspiration to do something new.
Old Dec 17, 2008 | 08:13 AM
  #73
NCC-2000's Avatar
They say no longer than 1.5 HOURS? Jeez, I installed mine in less than five minutes. This ain't rocket science, it's really simple.
Old Dec 17, 2008 | 08:17 AM
  #74
restonSS's Avatar
317 bucks for taillights? buy injectors, stage 2 belt, and a 2.7 pulley! lol
Old Dec 17, 2008 | 07:12 PM
  #75
TheCaptain's Avatar
Haha, yea i know eh?! I guess they made it look good for the mechanically inclined.
