Official Retrofit Thread
Old Nov 8, 2015 | 04:26 PM
  #2476
CobaltSS 16's Avatar
I have my switch hidden where my trunk button is
I like that too
Old Nov 16, 2015 | 01:09 AM
  #2477
Sharkey's Avatar
after 8 years of dealing with my terrible headlights in my balt ive taken the plunge. my order from retrofit source showed today
-mini d2s projectors
-bullet shrouds
-xb35 ballasts
-xb 5500k bulbs
just waiting for my new housings to show up now.
Old Nov 16, 2015 | 11:09 AM
  #2478
I like that too
So you like it both ways?
Old Nov 16, 2015 | 07:06 PM
  #2479
Sharkey's Avatar
didnt even have the headlights for an hour before they were in pieces. already got the projectors mounted in the reflectors and prepping to paint everything. cant believe how easy its going thus far. going to black the reflector and chrome, except for the turn signal reflector area, thats staying put. just dont know if i want to leave the shroud chrome or black it out.
ill have pics once i get some paint on.
Old Nov 16, 2015 | 08:33 PM
  #2480
I'll give it both ways lol... not receive. I aint swing like that rIc3
Old Nov 17, 2015 | 01:47 AM
  #2481
Sharkey's Avatar
ready to go into the car for alignment before final assembly. they are nothing real crazy, just a simple blacked out headlight. im more concerned about performance of them than looks.
Old Nov 17, 2015 | 03:05 PM
  #2482
Fsanti87's Avatar
I'm certain the answer is no but does anyone have a trick to keep the headlights from turning on when I unlock the car with the remote? Not including using the key lol
Old Nov 17, 2015 | 06:07 PM
  #2483
kcg795's Avatar
There's a setting in your DIC settings. Your manual should say how to access these settings. Or you can go to https://www.cobaltss.net/forums/gene...tup-menu-2562/. There is a setting for the headlights. No need for them to come on high beam when I unlock my car.
Old Nov 17, 2015 | 08:31 PM
  #2484
Fsanti87's Avatar
Oh awesome! Thanks I figured that was one of the features you just can't disable. At least not without a relay or capacitor
Old Nov 18, 2015 | 12:43 AM
  #2485
kcg795's Avatar
I was able to tap into the DRL fuse slot with a relay and run that to my LED halos. Now they work just like DRLs.
Old Nov 18, 2015 | 12:31 PM
  #2486
Fsanti87's Avatar
Mine doesn't use the headlights as the drl. I was only concerned with slowly killing the bulbs every time I unlock the car
Old Nov 21, 2015 | 09:37 PM
  #2487
Sharkey's Avatar
anyone had issues with the morimoto relay harness? i switched the pins around to match 9007 wiring as everything i read said they are pinned for 9004 bulbs. my issue is no high beams. the lights stay on when i hit the high beams however the shudders dont move. shudders work when manually tested, i have high beam input from the car, but no output from the relay box/module. and my high beam indicator is functioning correctly.
seems like a bad module. im going to double check my wiring but im 99% sure ive got it correct.
Old Nov 22, 2015 | 01:23 AM
  #2488
Ive had a few harnesses go out on me unfortunately. If the nipple on the plug from the projecto is facing up at you, what sides are the wires (black and red)?
Mine are [black'red]
Old Nov 22, 2015 | 02:17 AM
  #2489
Sharkey's Avatar
the shudder wiring on mine is white and brown, and i put it together as per the instructions on trs's site.
i think i might have had the wiring pinned wrong on the input side. i found some other info and pinned it to that, ill give it a try tomorrow.
Old Nov 22, 2015 | 04:47 PM
  #2490
Sharkey's Avatar
I had the input plug pinned wrong. Got it straightened out and it all works. Now to bake the headlights and install them
Old Nov 22, 2015 | 05:40 PM
  #2491
Finished a dual projector setup last night. Pics to come..
Old Nov 22, 2015 | 05:55 PM
  #2492
EmperorJJ1's Avatar
quads are the ****. im interested in how you did them
Old Nov 22, 2015 | 07:19 PM
  #2493
saw the pictures on facebook. nice work.
Old Nov 22, 2015 | 07:49 PM
  #2494
Come on rice post some pics up
Old Nov 22, 2015 | 10:22 PM
  #2495
Well here they are. Matchbox MH1s for the outers, D2S projectors with the led panamara shrouds for the inners.
All on at the time time highs or lows.
Outers have switchback halos and switchback led strips around the signal area.
They kicked my ass with trimming work and fitment and wiring but i think they turned out pretty awesome and its always great when everything works perfect first try.
Unaimed cutoff line
And even though it has no signal bulbs... I think they have more than enough signal. **** the halos could he used to SOS
Old Nov 22, 2015 | 10:24 PM
  #2496
Also finished another set today. And started another. Haha
These are just a simple D2S setup with white appollo shrouds for a purple car with mint wheels haha
Old Nov 22, 2015 | 10:27 PM
  #2497
They are sick rice good job
Old Nov 22, 2015 | 10:36 PM
  #2498
build retros for chevy colorados lol
Old Nov 22, 2015 | 10:56 PM
  #2499
I do build for colorados!
Old Nov 22, 2015 | 11:12 PM
  #2500
Coba's Avatar
Those are badass rice. That ring around where the running lights were is sick
