Official Retrofit Thread
Old Nov 3, 2017 | 06:02 PM
  #2601
Sharkey's Avatar
this is more than just road pitting, ill post a pic of them tonight, they are beyond sanding and clearing.
Old Oct 6, 2018 | 07:45 AM
  #2602
STC Karma's Avatar
I know this thread is a bit old, but is there anyone that still builds retrofits?
Old Oct 7, 2018 | 12:11 PM
  #2603
colodude18's Avatar
I built some for myself but I only build taillights for others. You may want to check with ECaulk he is local to me and does awesome work.
Old Oct 8, 2018 | 06:12 AM
  #2604
EmperorJJ1's Avatar
i mean if you wanted a unique set of gen 1 retros...
Old Jan 11, 2019 | 12:58 AM
  #2605
Sharkey's Avatar
so ive had my projectors in for 3 years now, complete with morimoto hids, performed flawlessly, but in the last couple months ive started having issues with the headlights not turning on the first try. of coarse my car having auto headlights i have to shut the car off and try starting it again, or using the switch while the car is off to get them to light, its a pita. it started as only one light doing it, now both are doing it intermittently (sometimes the left, sometimes right, or sometimes both) making me lean towards it not being the harness and relay. is this more than likely caused by bulbs that are failing? its kinda what im leaning towards, but id hate to buy another set of bulbs only to find out its the balasts.
whats everyones opinion of led bulbs in a projector? i was looking at them, but im having a bit of a hard time finding a d2s led bulb thats 5000k or under (i like my 5500k hids but in my area the cops are going nuts issuing vehicle inspections for things like this, so i think its wise to go with a less conspicuous bulb temperature).
Old Jan 11, 2019 | 06:44 AM
  #2606
Have you double checked the wiring? I might have a spare good ballast I could ship to you to find out if it is that.
Old Jan 11, 2019 | 08:04 AM
  #2607
One of my lights is doing that, when troubleshooting I found that the connector from ballast to wiring harness for my d2s projector are some what loose and dont always make good contact
Old Jan 11, 2019 | 02:52 PM
  #2608
Sharkey's Avatar
yea ive checked the wiring, nothing jumped out at me. ive got spare ballasts i could play with if i need to.
i think im gonna try a new pair of bulbs. i read a bit last night about how later in life the bulbs tend to move up the color scale, my 5500k bulbs are giving off a lot of blue, almost more like an 8000k bulb. i also read that it can be harder for the bulbs to ignite when they get to this stage.
Old Jan 11, 2019 | 04:11 PM
  #2609
EmperorJJ1's Avatar
if the bulbs dont work i might have some spare parts for you as well
Old Oct 12, 2019 | 09:16 PM
  #2610
heeter_33's Avatar
I know this an old thread, but anyone know what rice used to make the evil eye? Shrink tubing? Electrical tape?
Old Oct 13, 2019 | 08:17 AM
  #2611
I think he painted over the halo.
Old Oct 13, 2019 | 01:14 PM
  #2612
heeter_33's Avatar
Thanks, ECaulk. Another question for you or anyone else that still views this thread. I want to run switchbacks as my front turn signals, but I'm not sure what the best way to go about that is. I'm assuming I'll have to somehow split the DRL signal into the turn signals so the white is illuminated when the signal isn't? Further, I want the halo to be a switchback as well, so that turn signal input will somehow have to be split into the halo? Someone already make a harness for this?
Old Oct 16, 2019 | 11:59 PM
  #2613
EmperorJJ1's Avatar
id just pull the DRL fuse
Old Oct 19, 2019 | 11:36 AM
  #2614
heeter_33's Avatar
I want the halo and the switchback signal (in white) to serve as the DRLs. Might make more sense if I had everything in front of me to sort out, I'm just trying to get it all figured out before I order anything.
Old Oct 20, 2019 | 11:14 AM
  #2615
You're going to have to disable the DRL fuse and run the halo DRL off a switched fuse circuit. Or you're going to be pulling apart a wire loom to separate the DRL wire from the high/low headlight wire.
Old Jan 18, 2021 | 12:13 PM
  #2616
ProfDNS's Avatar
Reaching out to see if somebody can give me a hand:
I bought these from Royce a while back and had them on my GT (some of you know that story) and the housing on both are trash - the clips that hold the headlight in place are sheered off, major damage to the dome, etc. I finally started taking these apart but I'm not sure if I have to take the whole light dome out or if it's only the front cover.
Spoiler
Old Jan 18, 2021 | 01:56 PM
  #2617
It looks like you'll need to remove the entire assembly there. There should be three spots it's mounted to in the plastic housing, a little bit of heat and leverage and you can get them to pop out
Old Jan 18, 2021 | 03:58 PM
  #2618
ProfDNS's Avatar
I thought so, but wasn't sure. I'll heat it up again and see if they'll just pop out. There is a hairline crack on that black housing part so I might hit that with some heat resistant putty.
Old Jan 18, 2021 | 06:44 PM
  #2619
If you're talking about the black part the the metal ball is in, let me know if it's broken. I may have a few of those lying around from back when I did retrofits
Old Jan 19, 2021 | 05:00 PM
  #2620
chevygirl2006's Avatar
Old Jan 19, 2021 | 05:02 PM
  #2621
  #2622
BLK08SS/TC
Jun 6, 2012 06:42 PM
breds2k
Mar 11, 2012 10:37 PM
allblacked
Jun 30, 2011 06:29 PM
