Paint Scuff Need Advice
Old Oct 2, 2008 | 11:00 PM
hilty003's Avatar
I got a scuff on my rear bumper. its mostly light looking scratches within a 3 by 3 inch area. its on black so they show up if you look at the right angle. anyone have any luck with any scratch removing product? ive tried waxing and buffing and even tried to even them out with a lil bit of light rubbing compound but im not having any luck. please help. thanks.
Old Oct 2, 2008 | 11:08 PM
lt1 gun's Avatar
you can try wetsanding it with a 2000 gritt wetsanding paper. just make sure u use enough water...then all u have to do is buff out the wetsanding scratches = ]
Old Oct 2, 2008 | 11:12 PM
G85 SS's Avatar
Don't go to that extreme if you don't have to. Use that for the last resort....
Best thing you can do right now is you a semi-abrasive wax and a buffer on the area needed. Then finish it up with a polish and a protectant wax. If that does not work, then resort to the wet sanding.
I have Meguiars Mirror Glaze line which is a professional line and they make abrasive products for this...You can find them at Pep Boys. regular wax will not get rid of a scuff.
Old Oct 3, 2008 | 05:30 PM
hilty003's Avatar
that semi-abrasive wax sounds like its worth a try. i use meguiars spray detailer and love that so im definitely goin to look into them then. do you know if theyd car that at like an autozone off hand? i have more of those than a pep boys....i actually cant even think of any around here. and if i do resort to the wet sanding, ill be able to fade it back into the paint around it so that you cant tell? seems like sanding would only make it worse...
Old Oct 3, 2008 | 05:37 PM
ChevyRockstar's Avatar
DONT do this only made mine worse few weeks back
Old Oct 3, 2008 | 06:47 PM
hilty003's Avatar
did you figure something out? if i really cant get this fixed i guess my last resort is taking the bumper off and gettin it repainted in the spring.
Old Oct 3, 2008 | 06:50 PM
cougar2588's Avatar
they have a few different decent rubbing compounds (basically the same thign as abrasive polishes) at autozone. if you wanted to do it the right way, you would have to go at it with a rubbing compound, then a mild/light polish, then a glaze or wax.
edit: if you could post a picture with good lighting i could probably be a little bit more specific as to what you have to do. also, if you get ur hands on a good picture shoot hattrickstu (or something like that) a PM, i kno he details cars too and has more experience then me, or send Turbowax a PM, they will definately be able to guide you in the right direction.
Old Oct 3, 2008 | 07:02 PM
No i havent
Old Oct 3, 2008 | 07:10 PM
hilty003's Avatar
thanks. i appreciate it. ill see if i cant get a decent pic up tommorrow to show. i tried to a lil turtle wax rubbing compound without much luck
Old Oct 3, 2008 | 07:15 PM
GSMiller's Avatar
Wetsanding is overkill. Someone hit my passenger side door with theirs while getting out of their car and got scuffs on my paint. Some Meguiars ScratchX got it off no problem. Scratch Doctor is really good too, just buy what you think is the better value (if you don't already have some).
Old Oct 3, 2008 | 08:18 PM
cougar2588's Avatar
im guessing you did it by hand, but what did u use to apply the rubbing compound?
Old Oct 3, 2008 | 08:24 PM
hilty003's Avatar
yea i did it by hand with a soft cloth
Old Oct 3, 2008 | 08:31 PM
cougar2588's Avatar
well theres your problem lol. honestly your probably not going to be able to find the pad that needs to be used with a rubbing compound at a local autozone.
i'll wait till your able to post more pictures tomorrow before i send you on a goose chase on what products will be needed. but like i said, dont hesitate to PM either of those two ppl i mentioned before since they have more experience/knowledge about this stuff then me.
Old Oct 4, 2008 | 08:35 PM
hilty003's Avatar
ok so heres the pics...
this is from a few feet back, u can see the spot below my bent knee
heres one from a side angle so you can see the dullness
heres a few close ups
heres just one of the rest of it, im hoping to get it back to as glossy as the rest of it
so any help you can give id really appreciate. im pretty much willing to try anything. little nervous about the porter cable stuff ive been looking into but probably willing to try if its really gonna work. thanks for your help.
Old Oct 5, 2008 | 12:22 AM
cougar2588's Avatar
after seeing that its definately scuffed and lightly scratched. not sure how deep the scuff mark is or how rough the paint is. but if the paint is really rough/cant run your hand over it smoothly, you might have a more serious problem. if not, id say a porter cable is going to get you your best results.
there is a way to do it by hand if u dont wanna spend the $200 on a porter cable, the results wont be AS good, but it will definately improve it depending on the actual condition of the paint. its late right now, so tomorrow if i get a chance too ill do a quick research on one of the detailing forums im on and let you know what products to order online that you can use by hand.
if you wanna, check out autopia.org and autogeek.net. those are two VERY reputable deailing forums with tons and tons of info. heck, join, post these pics, and im sure those guys can help/guide you through what to do.
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
DocSvensk
Sep 27, 2015 02:24 PM
riceburner
Sep 26, 2015 12:57 AM
