Painting the dash
as for the steering wheel bezels its easier then it sounds. i do recommend disconnecting your battery though since you are dealing with your air bag and if it accidently grounds out, it can set off the air bag.
now as for getting the air bag out, there are 2 lil holes on bottom sides of the steering wheel. inside those are little push clips. it'll take a few minutes to find them but take a small flat head screwdriver and put it in there and when you find the tab push in and pull lightly on that side of the air bag and it should come up. repeat on other side and pull your air bag off. then its pretty straight forward from there.
ya its just a little push tab that you push over and lift up on it with the screw driver. a pick works much better.
https://www.cobaltss.net/forums/how-guide-43/how-paint-your-dash-21673/
23 pages of trim painting
https://www.cobaltss.net/forums/how-guide-43/how-remove-bezels-steering-wheel-84011/
removing steering wheel trim
I got color matched paint from Automotivetouchup.com it's the general consensus on the forum that duplicolor makes the best products and yes you should clear them for the best shine/durability.
Looks pretty sick, I re-did mine...kept it silver and cleared over it. Also just got done putting in the LED tail lights and Trim under the hood!
camaromanss1992
Oct 1, 2015 10:51 PM
