Painting Headlights
Old Jun 22, 2007 | 07:27 PM
OrngBalt's Avatar
Painting Headlights
Ok before you flame I am not asking how to. I just want to know how much paint it took you guys to paint them. I did another project today and it took more than I expected. I am going to have one full can of color match from GM and potentially enought for a couple light passes. You guys think I should be ok?
How much did you use?
Old Jun 22, 2007 | 07:30 PM
cheesetits's Avatar
You're just doing the eyelids right? You should be good with 3 passes. I did that on my old car.
Old Jun 22, 2007 | 08:51 PM
OrngBalt's Avatar
Nope, taking apart the assemble and painting the inside. Instead of doing black I am color matching
Old Jun 22, 2007 | 09:00 PM
ptrblkz24's Avatar
Buy 2 cans to be on the safe side.You shouldnt need more than that.
Old Jun 22, 2007 | 09:04 PM
05REDROCKET's Avatar
Yeah two cans of paint and two cans of clear coat.
Old Jun 22, 2007 | 09:10 PM
Jusday's Avatar
yeah i used a full can of duplicolor on the lights... they are twice as big as gm matched...so ull need another in my opinion
Old Jun 22, 2007 | 09:52 PM
smartmts123's Avatar
i used 1 1/2 of the color-matched stuff from GM (sounds like what you're using). Although, I did mess up the first time, so I had to repaint... 1 would have been enough if i was more careful.
Old Jun 22, 2007 | 11:05 PM
RaineMan's Avatar
You mean you want something like this eh?
Old Jun 22, 2007 | 11:07 PM
OrngBalt's Avatar
^^^ Yea eh, I recognize those by the nightshades... Jackalope do those for you?
Old Jun 22, 2007 | 11:17 PM
RaineMan's Avatar
Actually WDSoccer... heheh... I love 'em.
Old Jun 22, 2007 | 11:56 PM
OrngBalt's Avatar
I like them cuz they are different with the nightshade. It's a real good touch. I was gonna go clear corner, but then I realized that might actually stand out more since I am color matching Orange
Old Jun 22, 2007 | 11:59 PM
RaineMan's Avatar
I'd definately go with the nightshades on the side markers... that little bit of black looks so nice in there.
Old Jun 23, 2007 | 12:26 AM
Jusday's Avatar
yeah i did that too...like 2 coats and it matched well with the black paint
Old Jun 23, 2007 | 04:23 PM
OrngBalt's Avatar
Hey guys, so Here I am... They are out of the car and they have been in the oven. But.... I CAN'T GET THE HOUSING APART. The silicon is soft and I can get a screwdriver in, But i can't pull or pry it apart. Anyone have suggestions? I do not want to install them back in my car without finishing this project
Old Jun 23, 2007 | 04:26 PM
Jusday's Avatar
idk about the oven thing...i suppose it would work but when you pull them out the silicon will start to cool. use a hair dryer and keep it pointed in the high/ low beam entrance. then when you pry the pieces apart with a screw driver cut the siliconwith a razor. keep doing this for about half way down the light on both sides and then you can pry it apart by hand
Old Jun 23, 2007 | 04:31 PM
OrngBalt's Avatar
I've heard alot of good with the oven. Maybe a combination of the two heat in the oven and then use the hair dryer. Thanks for the tip.... anyone else try this?
Old Jun 23, 2007 | 04:54 PM
RaineMan's Avatar
as far as I know the oven thing works... but you will need several screw drivers... leave them in as you move around the light... or it will reseal.
Old Jun 23, 2007 | 04:58 PM
Jusday's Avatar
yeah i learned better after the first light...my fingers were quite sore from holding it open
Old Jun 23, 2007 | 05:23 PM
OrngBalt's Avatar
All right, we giving it another shot. I have the razor blade, 4 screwdrivers and the hair dryer....
I am going to make this work
Old Jun 24, 2007 | 09:19 AM
HEAT GUN!! seriously. spend the $20 and pick up the low-end one at home depot. works great. Other than that, yeah, flathead screwdrivers and razor knife. Try not to pry too far without cutting it off - you'll warp the headlight a little.
chefhhr
Oct 26, 2015 10:36 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
riceburner
Sep 26, 2015 12:57 AM
