Really cool Idea, new help
Old Oct 12, 2006 | 09:09 PM
Xavipheus's Avatar
Okay so I really want underglow neons, and I thought of the best idea. Is it possible to hook them up to my interior dome lights? So that when I unlock my car the neons come on and when I open my door the neons come on, or when I slide the switch I can have them perm off or perm on? Would that be possible?
I only ask because its illegal in NJ and i really dont want to drive around with them on, so I think it would be cool to just have parked and whenever
Old Oct 12, 2006 | 09:41 PM
biniecki's Avatar
I would think it would be possible but you would have to find d where the module for the keyless entry is located. All the hookups for the interior lights and headlamps would be found in this one central location and you would have to wire them into this module. For that you may need a wiring diagram to see exactly how it works. Once you find where you find this out you will also need to find a constant 12V feed. Now for the switch you, i think you will need a Double Pole Double Throw switch also known as a DPDT but not possitive. The kind of switch would have 3 positions and about 6 terminals. 2 terminals for each possition. One connection would be connected to the keyless, one for the constant, and one that would just be grounds for off.
Old Oct 12, 2006 | 10:16 PM
Xavipheus's Avatar
Couldnt I just tap into the power for the dome lights? And the BCM would turn power on and off on those lines as needed
Old Oct 12, 2006 | 10:20 PM
Drakonen2000's Avatar
if you want a nice, big....FIRE!!!! the guage on that wire is gonna be to small to power the ballasts on the neons without some serious heat discharge man.....
sunrise_mj's Avatar
just use a relay coming off the dome lights power.
done
Old Oct 12, 2006 | 10:27 PM
Xavipheus's Avatar
Well there LED's so they dont use much power
Old Oct 12, 2006 | 10:29 PM
ah, i didnt catch that they were LED's....but just do what that other guys said...relay from dome power....DONE!!! thats the best way.
Old Oct 12, 2006 | 10:31 PM
stlurbanpunk's Avatar
just make a seperate line with its own fuse, that is the only way i would do it. however i am electrical retarded, so my way would indeed be the simplest.
Xavipheus's Avatar
Anyone know where I could find one?
Old Oct 12, 2006 | 10:38 PM
BlackLS's Avatar
Most undercar kits come with a switch so you can turn them on or off whenever you want to and doing it this way would save you alot of work.
Old Oct 12, 2006 | 11:04 PM
Xavipheus's Avatar
But it just wouldnt be as cool lol
Old Oct 13, 2006 | 12:16 AM
Maccoy316's Avatar
yes it can be done, my friend has it set up to a 12 volt connection in his car so he can turn it on whenever he wants.
Old Oct 13, 2006 | 12:24 AM
joeworkstoohard's Avatar
it would be a bitch to get power for a relay from the dome... because, you'd have to tap it up high since that's where the light is... could be done, but would be a bitch, lol.
Old Oct 13, 2006 | 07:36 AM
EmperorJJ1's Avatar
lol ya it would be cool to see you unlock the doors with the fob and see the leds come on
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 20, 2015 09:56 PM
tomj77
Oct 4, 2015 11:39 AM
Tupp
Sep 30, 2015 08:18 PM
Rduncanss06
Sep 27, 2015 11:17 PM
