Swapping trunks? Question..
Old Feb 2, 2009 | 09:24 PM
averagewhiteboy's Avatar
Alrighty, so, I was wondering on how hard that basically "swapping" trunk lids would be.. I mean, buying one from a junkyard (or elsewhere), and using it on your own car.. That would include removal of yours (and perhaps the "new" one), as well as key hole exchanging, trunk struts, alignment, etc. I know that the light swapping is simple, but I've never done a full trunk before, only a hood.. Any help would be cool because I want to do this come Spring..
Thanks!
Old Feb 2, 2009 | 09:26 PM
ilovecars's Avatar
real simple you could even leave all that other stuff on just take off the strut and the 4 bolts holding it on. then you can just un plug the lights and plug em back in. dont over think it its really quite simple.
Old Feb 2, 2009 | 09:45 PM
How about the trunk key area?
Old Feb 2, 2009 | 09:46 PM
ilovecars's Avatar
theres just a metal clip that you pull off and then you can take it out np.
Old Feb 3, 2009 | 06:18 PM
StevesBlack06's Avatar
the lock can be a bugger if you have never done it before tho. but if u have done it once its easy
Old Feb 9, 2009 | 05:09 PM
Anyone have a real how-to on the key hole? Pics or anything? I'm doing this on Saturday, and I don't want to waste alot of time.. I'm sure we can both figure it out, but I'd like to be extra sure..
Old Feb 9, 2009 | 06:18 PM
ilovecars's Avatar
idk if there is a how to but its really easy theres this metal "clip" sort of thing near the back side of the key hole it holds it in. you just pull that out take the key cylinder out and then once your done swapping put it back in and clip it back on.
Old Feb 9, 2009 | 09:23 PM
yobrigidey's Avatar
I just swapped trunks last night within an hour. It was really easy.
For the lock, there is a metal clip. Look up under the lid at the lock area and you will see it. If you are looking at the trunk from behind, the clip will slide to your right. Just grab the big "handle" and pull right, and it'll slide right off. Then the lock will pull out from the exterior of the trunk lid. Pay attention to how the lock is installed. It has a long "prong" on the left side, make sure you insert your the same way. Then, install yours and slide the metal clip back in. It takes a couple tries to get it to lock in real well, just make sure there is no play in the lock and you are good to go.
Old Feb 9, 2009 | 11:42 PM
And then for the trunk it's self it's just a few bolts?
Old Feb 10, 2009 | 08:29 AM
ilovecars's Avatar
yes its really not that hard to do so dont over think it.
Old Feb 10, 2009 | 10:11 AM
Awesome. I'm sure that between both of us we can work it out.. haha
Any idea what kind of sockets or whatever you need to use for the trunk..? Anything off the top of your head..?
Old Feb 10, 2009 | 10:17 AM
forced_induction's Avatar
glad to hear it is easy to do, just need to find a wingless vic red trunk
Old Feb 10, 2009 | 10:22 AM
haha
Is ANYONE happy with their stock spoilers..???
I just find the low-pro so damn boring.. The posts that it stands on are also WAY too fat.. Plus, even if I don't like the high-rise, it's always easier to trade a high-rise for a clean trunk than it is to trade a low-pro for a clean trunk.. lol
Old Feb 10, 2009 | 10:34 AM
Originally Posted by averagewhiteboy
haha
its not that i don't like the look of my high rise, I just prefer the less "hey look at me" appearance of going wingless, plus i wanna know what it is like to see out my back window without a huge red line blocking my view lol
Old Feb 10, 2009 | 10:36 AM
haha Gotya. Red coupes you generally see with low-rises, rarely ever clean trunks.. That sucks dude..
Old Feb 10, 2009 | 11:45 AM
yea i know, i have seen a few around here but never parked to be able to talk to them and try to get a trade, gonna have to look around junkyards this summer for one
Old Feb 10, 2009 | 01:17 PM
ilovecars's Avatar
not off hand but i know there all metric measurements as is all bolts on the cobalt YAY METRIC!
Old Feb 10, 2009 | 01:33 PM
yobrigidey's Avatar
I'll check what socket is still on my wrench when I get back home. You'll need a shallow socket to get the bolt off of the rear bracket. I'll get some pics up here tonight.
Seriously though, if you can eat a cheeseburger you can swap a trunk lid.
Old Feb 10, 2009 | 03:19 PM
bumm81890's Avatar
Try fining a swap for a blurple one....I've been looking since I got my car and no luck.....no junkyards either
Old Feb 11, 2009 | 10:20 PM
yobrigidey's Avatar
Okay, sorry it took an extra day.
You can see the bolts that got the paint rubbed off of them from the rachet. You'll need a 13 mm shallow socket is all. There are 4 bolts, two on each side that holds the whole bracket on.
Old Feb 12, 2009 | 02:25 AM
Those four are the only things holding the trunk on? Aside from that, you just need to remove the key hole and the harness for the lights?
Old Feb 23, 2009 | 07:01 PM
CinciSS07's Avatar
bump. about to do this wednesday, is that correct? and how easy is it messing with the wiring harness
Old Feb 23, 2009 | 07:57 PM
Buckweed's Avatar
hard part is the u clip
Old Feb 23, 2009 | 08:01 PM
The kid that I swapped with did this, but basically you just kinda feel your way through it.. Didn't seem too hard. I just need to allign the trunk properly.. It's a tad bit in..
Old Feb 23, 2009 | 09:42 PM
Opi's Avatar
Opi
^Correct
I switched out our trunks. Wasn't too terrible... Be sure to take out the latch to get the sensor off the trunk. That had me stumped for about 15 minutes
ThoR294
Oct 4, 2015 08:44 PM
ThoR294
Sep 28, 2015 05:31 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
