What kind of paint?
Old Jul 28, 2006 | 04:12 PM
biniecki's Avatar
What kind of paint?
I am going to do the painted headlight mod this weekend and was currious as to what type/brand of paint everyone used or recommends for doing this. Also is a clear coat needed? Thanks
Old Jul 28, 2006 | 04:18 PM
KillerNutz's Avatar
I used the dupli-color touch up spray paint on mine, but they are color matched. I helped another guy paint his black, and he just used high temp black engine paint. Also, I used clear coat on mine but not on his, so its really up to you. any questions pm me.
Old Jul 28, 2006 | 04:31 PM
05REDROCKET's Avatar
If you use duplicolor or any color other then flat black you must clear it or it will look dull and may peel.
Old Jul 28, 2006 | 04:55 PM
GSoccer24's Avatar
1.) mask any areas you don't want paint on.
2.) prep the surface with a red 3M scuff pad, very lightly
3.) use a duplicolor prep wipe to clean the surface
4.) wipe the surface with a tack cloth or a clean, dry, lint-free towel/rag
5.) spray 2-3 light coats of a self-etching or plastic primer over the area to be painted
6.) apply 3-4 light coats of your preferred duplicolor color, followed by one medium coat, being careful not to cause any runs
7.) if the surface is not glossy enough, follow with 2-3 coats of clear
8.) let dry for at least 5 hours
9.) reassemble headlights with silicon sealant
10.) reinstall headlights into vehicle
06MetallicBalt
Jul 20, 2025 08:47 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
riceburner
Sep 26, 2015 12:57 AM
