BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old Sep 21, 2010 | 03:31 PM
  #226
mkulrey13's Avatar
PLug the working light into the side that has no high beams. If it still doesnt work you can send back the harness for a replacment
Old Sep 21, 2010 | 04:01 PM
  #227
hook's Avatar
the old swap a roo
Old Sep 21, 2010 | 04:33 PM
  #228
DoMiStIc_RuSh_06's Avatar
What wires did you guys hook up they halos to....not sure which wire to use from the parking light harness....
Old Sep 21, 2010 | 05:03 PM
  #229
CudaJoe's Avatar
its the black and red one that are just bare copper wire.
Actually I'd like to know the steps to hooking these up to the parking lights as well. Or I'd like to see someones switch idea, or maybe the remote switch idea.
Old Sep 21, 2010 | 05:26 PM
  #230
RHZ's Avatar
RHZ
i spliced my halos into the ground and running light of the blinker. They go on with my parking lights and when i turn my fogs on.
Old Sep 21, 2010 | 05:48 PM
  #231
davebetterthanu's Avatar
I guess I can take pics on how I hooked up the halos to a separate relay and switch
Old Sep 21, 2010 | 05:50 PM
  #232
CudaJoe's Avatar
I was just googling wireless switches, lol. You have it wireless right? Thats what im interested in. Maybe a key FOB switch.
Old Sep 21, 2010 | 05:53 PM
  #233
CudaJoe's Avatar
EasySwitch Four Button Key Fob - Transmitter
Im thinking something like this might be cool. too bad its not one button, or rather have the trunk, door unlock, door lock, and halos on it.
Old Sep 21, 2010 | 06:04 PM
  #234
No it's wired lol
Old Sep 21, 2010 | 07:01 PM
  #235
CudaJoe's Avatar
awwww, you have the switch inside the car? If so, where's the grommet to go through>
Old Sep 21, 2010 | 07:52 PM
  #236
Maupin SS/SC's Avatar
its a giant ruber grommet underneath by your pedals...cant miss it really
Old Sep 21, 2010 | 08:47 PM
  #237
what color was the wire that you spliced the + wire of the halo into?
\Im just gonn splice the ground of the halo into the ground for the hids
Old Sep 21, 2010 | 09:08 PM
  #238
mkulrey13's Avatar
Ive explained this 100x's LOL. the small bulb on the headlights (sidemarker) you use those wires. Brown is power.
Old Sep 21, 2010 | 09:50 PM
  #239
G Speed's Avatar
Light output/color looks fine? altho my fogs have the Z cutoff.
So this morning, I got in my dad's 7 series... I parked it pretty close to the garage wall, so when I started up the car.. I noticed something about the hids... the cut off was perfect, but I also noticed a line in the middle of each beam...
So I got out of the car it was the shadow of the bulb on the wall... then I realized I could see the position of the bulb... the insulator was straight up
So went over to my car, noticed my driver the one was upside down... and passenger was tilted..
Tightened passenger it was perfect
Driver.. no go, looks like from the manufacture they put the little tabs in the wrong spot.. so I filed one off... and bam PERFECT cut and color now matches lol
Old Sep 22, 2010 | 12:39 PM
  #240
ok....one last question.....Using the side marker on the headlight to wire up my halos.....Which one of the black wires are grounds....There is 2 black wires. I didnt wanna hook it up wrong and end up ruining the halo.
thanks
Old Sep 22, 2010 | 03:15 PM
  #241
mkulrey13's Avatar
thanks
I used the one running off the blue 9007 connector.
Old Sep 22, 2010 | 06:46 PM
  #242
slvr 04 rl's Avatar
is there a left and right side projector? or does it not matter?
Old Sep 22, 2010 | 07:45 PM
  #243
mkulrey13's Avatar
There both the same.
Old Sep 22, 2010 | 08:58 PM
  #244
slvr 04 rl's Avatar
oh ok just wondering. but why do they have a little angle on both of them to the right?
my car doesnt run right now so i cant pull it to much farther down the driveway. so idk if i am to close to the wall or what? but i would think it should all be flat
Old Sep 22, 2010 | 09:02 PM
  #245
Mines like too
If I would have known it was that angled I would have modded the cutoff
Old Sep 22, 2010 | 09:03 PM
  #246
mkulrey13's Avatar
holy hell are you like 10ft away? take a picture 30+ft away lol
Guys cutoff lines are designed to be higher on the right side of the road as theres no on comming traffic...
Old Sep 22, 2010 | 09:06 PM
  #247
slvr 04 rl's Avatar
alright, well i cant move my car that far. so i guess if its suppose to be that way, ok. always thought they were suppose to be flat. it just looks goofy like this.
Old Sep 22, 2010 | 10:52 PM
  #248
Originally Posted by davebetterthanu
Mines like too
looks like mine move way back and aim them right and they look amazing on the road
Old Sep 23, 2010 | 07:31 AM
  #249
G Speed's Avatar
They are suppose to illuminate the signs on the side of the road
Old Sep 23, 2010 | 11:51 AM
  #250
ya ino mine are fine but theyre not 6k guaranteeeeed theyre yellow they look just like my moms lexus es350 and are less white than my old 5k kit
