BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old Oct 7, 2010 | 03:41 PM
  #276
ChevyRockstar's Avatar
Mike thanks for the tracking email about my ballast warrenty
/threadjack
Old Oct 7, 2010 | 09:15 PM
  #277
N1ckateen's Avatar
got both headlights wired identical but the passenger headlight is stuck on high beam. i have switched the white and blue wire and switched them back and neither will work. idk how much more switchin the wires can take before the tip breaks and then i'm screwed. on the drivers side the blue wire is in the middle and the white wire is on the side so i have the passengers side the same way and no matter if i have the lows or highs on the passenger is stuck on high beam... what do i do!?
Old Oct 7, 2010 | 09:51 PM
  #278
DoMiStIc_RuSh_06's Avatar
my drivers side hid is flickering and my drivers side fog light isnt as bright as the other side.....What would be the cause of this?
Old Oct 7, 2010 | 11:34 PM
  #279
mkulrey13's Avatar
Guys 99% of these problems as mentions is your own wiring. Check grounds as well. Is the relay gets wet for the projectors, they can flicker go out and cause issues. MAKE SURE THEY STAY DRY.
Old Oct 8, 2010 | 01:13 AM
  #280
LS6Rally's Avatar
^ Yes my relay got wet and my Drivers side headlight would just stay on all the time. if it got wet, remove it and use a blow dryer to dry it out, or let it air out
Old Oct 8, 2010 | 06:15 AM
  #281
I'm gonna try a few things this weekend to see if I can solve the issue. If not I'll be in touch with you mike
Old Oct 8, 2010 | 10:24 AM
  #282
mkulrey13's Avatar
Were closed from tomorrow till the 21st.
Old Oct 8, 2010 | 12:19 PM
  #283
Maupin SS/SC's Avatar
my light completely filled with condensation after two weeks... could it be because the back is open where the big rubber circle is...? idk waht to do cause if u look through the back its always open there even if its sealed good. its only one light too which confused me?!
Old Oct 8, 2010 | 12:47 PM
  #284
mkulrey13's Avatar
Did you seal them yourself? You reuse that rubber thing and projectors come with another one to cover the bulb..
Old Oct 8, 2010 | 01:30 PM
  #285
ya i did. i have them done right one is filled with condensation now but not the other maybe theres a really tiny crack somehwere? i may let them dry out someday then reseal is more or something is that how it workS? but if you look in the back you can see to the front if you look to the side of the reflectors so technically its always open somewhere??!
Old Oct 8, 2010 | 10:00 PM
  #286
dayhoff35's Avatar
i cant get the chrome piece off where you have to unscrew the thing in order to put the projectors in how do i get it off?
Old Oct 8, 2010 | 10:58 PM
  #287
JoshuaVnyrd1817's Avatar
If your talking about the little piece in front of the bulb, check page 3.
Old Oct 8, 2010 | 11:16 PM
  #288
dayhoff35's Avatar
I'm trying to get the big chrome piece that that's connected to off my lights have black bracket things that are fastened on over top silver ball things and I can't get them off
Old Oct 8, 2010 | 11:24 PM
  #289
dayhoff35's Avatar
Nevermind I got it
Old Oct 10, 2010 | 07:37 AM
  #290
WickedSS2005's Avatar
Where's tshe shipping refund Ford the advertised "free shipping". Never got that back. I know I was told of some $5 handling fee or something but boats still not free shipping like advertised.....
Old Oct 10, 2010 | 10:37 AM
  #291
mkulrey13's Avatar
No such thing as a handling fee with us only paypal fees had to be covered. PM me please.
Old Oct 12, 2010 | 08:06 PM
  #292
G Speed's Avatar
anyone else's highs sometimes not turning off??
Like the cut of thing is sticking?
Old Oct 12, 2010 | 08:09 PM
  #293
LS6Rally's Avatar
^ mine was, my relay got wet. check that
Old Oct 12, 2010 | 08:12 PM
  #294
I noticed tonight, the headlight that was flickering, now the light output looks more of a yellowish color than the other side. Any ideas
Old Oct 12, 2010 | 08:15 PM
  #295
G Speed's Avatar
I just have to flick the lights again and it works....
example
1. start car
2. lights normal
3. turn high beams on "they both come on"
4. turn off high beams the shield moves into place
5. turn on high beams the shield moves "on"
6. turn off high beams.. driver side shield moves.. passenger doesn't "stuck on high"
7. flash my high beams, goes back to normal?
... sometimes it will also switch.. so driver side will stay on passenger goes back to normal
Old Oct 18, 2010 | 07:44 PM
  #296
Etak28's Avatar
Got the headlights installed today.. after some stupidity on my part.. (thanks a lot for putting up with me mkulrey13).
Let me tell you.... They look like sex. Absolutely amazing, cut off line is perfect, everything is perfect. They look just like tommypss/sc's thus they look like sex haha.
Too dark for pics tonight but hopefully i get some good ones up that do them justice tomorrow.
Thanks a lot guys, and for those that still need to install them... you won't be disappointed.
PS. Btw directions for installation are perfect just make sure you read and reread.
Old Oct 18, 2010 | 07:50 PM
  #297
HB_SS/TC's Avatar
I guess Ill check all the connections again but the passenger high beams don't work anymore
Old Oct 18, 2010 | 08:44 PM
  #298
kidcrash603's Avatar
If Mike was helping you today, he was doing so from Hawaii while he got ready to come home. Glad he was able to help!
Old Oct 18, 2010 | 10:05 PM
  #299
Etak28's Avatar
Well he helped me the last couple of days, but yeah he was great help with quick responses.
Old Oct 19, 2010 | 07:06 AM
  #300
mkulrey13's Avatar
I try guys I'm sitting in detroit now..waiting for my plane.
