BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old Sep 23, 2010 | 09:27 PM
  #251
JHans5774's Avatar
Were these supposed to come with sealant? You keep mentioning how you added it
Old Sep 24, 2010 | 09:14 PM
  #252
JHans5774's Avatar
I can't get my HID's to turno on I have everything connected correctly and the ground and the posiive hooked up the orange turn signal is on but the headlight won't turn on
Old Sep 24, 2010 | 10:24 PM
  #253
LS6Rally's Avatar
Check your ground!
Old Sep 24, 2010 | 11:14 PM
  #254
mkulrey13's Avatar
If everything is hooked up correctly, you would have some sort of power. Check your connections. #1 thing is people forget to plug in the stock harness to the cars wiring harness
You purchase it at your local walmart. RTV its called.
Old Sep 25, 2010 | 01:05 AM
  #255
JHans5774's Avatar
I have the ground hooked up under the fender bolt when I plug each headlight into the driverside they work I just have no high beams but I have tried both headlights on the passenger side and neither have worked any ideas? The positive is bolted down no fuses are out so I'm lost at this point could it be the harness?
Old Sep 25, 2010 | 03:07 AM
  #256
davebetterthanu's Avatar
Did you switch the blue and white wires around? If not you need to
Old Sep 25, 2010 | 09:13 AM
  #257
JHans5774's Avatar
Blue and white? On which harness i have not done that
Old Sep 25, 2010 | 09:26 AM
  #258
mkulrey13's Avatar
The projector harness's NOT anything stock.
Old Sep 25, 2010 | 10:28 AM
  #259
JHans5774's Avatar
Ok so it needs to be switched on both projectors and will that fix the high beam problem too? When i turn the brights on i hear a ticking noise coming from the fuse box. But switching the wires should get the passenger side to turn on correct?
Old Sep 26, 2010 | 08:33 PM
  #260
koch1ar's Avatar
How do the pins come out??? Anyone have a close up pic of what needs to be done to get them out?
Old Sep 26, 2010 | 08:45 PM
  #261
mkulrey13's Avatar
tiny flat head inside the connector to pinch down the clip.
Old Sep 26, 2010 | 09:06 PM
  #262
RHZ's Avatar
RHZ
Some dude actually got out of his car and started yelling at me for my lights being too bright. When i got home i tried to aim them down a bit....
I must have over-extended one my headlight aim screws because my light just dropped all the way down to the lowest setting and won't turn that screw anymore. I haven't looked at it real close yet but is there any way to repair that thing??
Old Sep 26, 2010 | 09:42 PM
  #263
koch1ar's Avatar
The little one on the flat side of the pin? How hard do I have to push?
Old Sep 26, 2010 | 10:39 PM
  #264
meckel's Avatar
I had a kit sent to me that had a CCFL halo wire and metal bracket popped out of the terminal. Can you guys check your 'Support@BuyHIDs.com' email, I'm just looking to get an answer to a question as soon as you get a chance.
Thanks!!
Old Sep 28, 2010 | 04:06 PM
  #265
LS6Rally's Avatar
Ok i got a question. i've had the lights in for about 5 days, and last night my drivers side Light wouldnt turn off. its on all the time. i disconnected the ground so it doesnt drain the battery. Any Ideas?
my guess is the relay ahrness but im not to sure.
Old Sep 28, 2010 | 08:24 PM
  #266
mkulrey13's Avatar
This happened to the lights i made for a friend in a accent. Did it once then never again..very strange. If the relay gets wet, i guess anything can happen.
Old Sep 28, 2010 | 08:27 PM
  #267
mkulrey13's Avatar
Thanks!!
We've already responded. We will send you another email tomorrow .
Old Sep 28, 2010 | 10:10 PM
  #268
LS6Rally's Avatar
so you think the relay may have gotten wet? it might have, i tried to do the best to mount it out of harms way. ill reconnect the ground when i leave work in a few so i can drive home. ill see what it does then.
if i swap lights and the problem persists, do i need a new relay harness. if so how much?
Thanks
Old Sep 29, 2010 | 05:28 AM
  #269
mkulrey13's Avatar
Thanks
We will inspect the relay and if we can cover it we will otherwise there 59.99
Old Sep 29, 2010 | 10:11 PM
  #270
LS6Rally's Avatar
i took a blow dryer to it last night, seems to work better. it does stick a bit and if you tap th erelay it goes out. its only the drivers side.
Old Oct 2, 2010 | 11:26 PM
  #271
iboost's Avatar
...i still never got that invoice for the g3 harness...
Old Oct 7, 2010 | 12:43 AM
  #272
RHZ's Avatar
RHZ
Everything has been working great until this morning in the garage i realized my right headlight projector wasn't working-- the halo still works fine. I checked the wires and the ballast and nothing was wrong. then i checked the bulb and found that inside the glass near the base of the bulb has white residue on it. Is my bulb burnt out already? There's no connection in the center bubble and there's 3 splats of green looking **** in that bubble too.
Old Oct 7, 2010 | 05:39 AM
  #273
mkulrey13's Avatar
Swap ballasts. almost always the ballasts.
Old Oct 7, 2010 | 09:08 AM
  #274
RHZ's Avatar
RHZ
I plugged the bulb into a working ballast and the bulb still wouldn't light. That's the second thing i thing i tried after checking all my connections. The bulb is definitely dead... the halos are still working great.
Old Oct 7, 2010 | 03:32 PM
  #275
mkulrey13's Avatar
Just a bulb that went out, simple fix already talking with you in PMs.
