BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old Sep 20, 2010 | 03:22 PM
  #201
Maupin SS/SC's Avatar
Originally Posted by davebetterthanu
^if you look at the pins there's a little tab that's keeping it from going out. Push those down and it should pull right out. It should be the blue and white ones to switch
thanks ill go do that after soccer practice tonight we had 2 games in two days we should get off early today
Old Sep 20, 2010 | 03:38 PM
  #202
mkulrey13's Avatar
Originally Posted by Chinelli3589
son of a....how do I go about ordering these?
May i ask why you need a pair? And to order them i can just send you an invoice. Let me know, if you order a pair i will knock a few $$s off for ya
Old Sep 20, 2010 | 04:04 PM
  #203
G Speed's Avatar
Did you get my e-mail yesterday? About the bad ballast & diff color bulbs?
Old Sep 20, 2010 | 04:07 PM
  #204
iboost's Avatar
cause I got a sent of the G3 retros from 3b specs ebay sight for pretty cheap, but they sent me the wrong harness and I can't get a hold of anyone from them so I said eff it. You guys have been customer service so I'm hoping that the harness will work
Old Sep 20, 2010 | 07:47 PM
  #205
mkulrey13's Avatar
Yes it will work.what harness did they send you?
No i do not belive so.
Old Sep 20, 2010 | 08:16 PM
  #206
G Speed's Avatar
okay I just sent the e-mail
Maybe the picture messed up..
Old Sep 20, 2010 | 08:32 PM
  #207
davebetterthanu's Avatar
^how come yours don't have that diagonal part on the light?
Old Sep 20, 2010 | 08:36 PM
  #208
iboost's Avatar
this one...
Old Sep 20, 2010 | 09:02 PM
  #209
G Speed's Avatar
it's my fogs...
Old Sep 20, 2010 | 09:14 PM
  #210
mkulrey13's Avatar
Light output/color looks fine? altho my fogs have the Z cutoff.
Old Sep 20, 2010 | 09:29 PM
  #211
DoMiStIc_RuSh_06's Avatar
Anyone have a diagram of the wiring for the hid fogs with the relay harness.....I looked at the one on the site but I have a bunch of wires with just prongs on them?
Old Sep 20, 2010 | 09:41 PM
  #212
hook's Avatar
Mike i wanna say thanks for being so easy to deal with and kind enough to help everyone with problems.
Old Sep 20, 2010 | 09:44 PM
  #213
CudaJoe's Avatar
he didnt help with my problem, he just said "look under the grommet, check the bolt" lol.
It's okay, he couldnt have possibly seen what happened to me as a potential problem. I honestly wouldnt have thought that was it but im glad it was. It was an easy fix.
Old Sep 21, 2010 | 01:05 AM
  #214
so do i seriously stick those prongs in where a harness would go it seems so unstable theyre there but um.. its weird.
Old Sep 21, 2010 | 05:37 AM
  #215
mkulrey13's Avatar
If there loose, i suggest you replace your stock harness plug because there not supossed to be. There designed to be wedged in and not move at all. As mentioned im going on 2+ years with no issues Just make sure they dont get totally wet. Wrap them in tape if you want.
Only prongs you use are from the relay harness and those plug into your stock harness.
Old Sep 21, 2010 | 07:40 AM
  #216
Ok.... There are a set of prongs with each hid bulb and the relay has just one set of prongs. What so I do with the set of prongs on the harness of each hid bulb
Old Sep 21, 2010 | 07:43 AM
  #217
G Speed's Avatar
Pull them out, if you are running the relay you don't need it...
that's if you want to use the stock wiring harness...
Old Sep 21, 2010 | 07:46 AM
  #218
So I just plug the one set of prongs from the relay harness into one of the harnesses for the fog lights? Then I must just tape up the ones on each bulb then?
Old Sep 21, 2010 | 08:08 AM
  #219
iboost's Avatar
Can you send me an invoice for these...I'll PM you my paypal...
Old Sep 21, 2010 | 09:57 AM
  #220
G Speed's Avatar
You can tape it if you want, I cut my boot and removed the wires... they aren't attached the light
Those wires are incase you don't have a relay harness
Old Sep 21, 2010 | 10:07 AM
  #221
I hooked them up without the relay do i need to add that to keep warranty cuz i will if i need to now i know what im doing i have only used them once
Old Sep 21, 2010 | 12:16 PM
  #222
hook's Avatar
stock harness
hid wires
which wires go to which plugs?
its labled a,b,c
can some one tell me for example the brown goes to a, white goes to c, and blue goes to b please
Old Sep 21, 2010 | 12:32 PM
  #223
C = brown
B = blue
A = white
Old Sep 21, 2010 | 12:44 PM
  #224
hook's Avatar
thanks boss
Old Sep 21, 2010 | 01:06 PM
  #225
hook's Avatar
C = brown
B = blue
A = white
ok i wired it like this and bam my hi's and low work..... no lol
well this is what im getting.
passanger and driver side lows. working fine
flip to high beams
passnager side on and driver side out.
i used my power probe to test the white wire on driver side and nothing going to it not power from the controler i guess. i put power to it with my power probe and my high beam works once it got power. could the wire be lose or just bad all? i dont want to take the controler apart lol
