Manitoba SS's 2011 Thread!
Old Jul 8, 2011 | 01:38 PM
  #651
soundjunky's Avatar
Originally Posted by Projekt
lol.
Sooo.. i might be flying. meaning ill have no vehicle in calgary.
I can lend you my bicycle
Might make driving the GF around a bit tricky though!
Originally Posted by yellow dragon
Well boys ZZP stg 3 is in and has a trifecta tune. Going to Gimli tonight and do a few runs. Stay tuned for results. So far the tune is good.
in for results!
  #652
jefferyss's Avatar
Ill give them to you to **** around with.
and ill even buy you a plate of wings.
Are you kidding? what a deal.
how can i *** around with them when ...
a) you havent told me what is/was wrong with them.
b) i dont have a cobalt to test any wiring out on them lol
Old Jul 8, 2011 | 02:23 PM
  #653
Projekt's Avatar
Sounds like your making excuses jeff
Haha. its all good anyways ill end up doing them this weekend.
Old Jul 8, 2011 | 02:57 PM
  #654
jefferyss's Avatar
pm me what is wrong with them
Old Jul 8, 2011 | 03:00 PM
  #655
Projekt's Avatar
The low beams do not work. i swapped the bulbs out, fuse and relays. has to be wiring .
Old Jul 8, 2011 | 03:31 PM
  #656
jefferyss's Avatar
you would have to run a test light to the bulb plugs themselves to see if there is power going to the lightbulb
  #657
Projekt's Avatar
Thats exactly what i am going to do tonight or tomorrow.
Old Jul 8, 2011 | 03:36 PM
  #658
jefferyss's Avatar
and then to the headlight harness itself to see if it has power when your lowbeam is on .
let me know, might be just a pinched wire somewhere.
Old Jul 8, 2011 | 03:40 PM
  #659
Projekt's Avatar
Thats my guess. or the hardness it self has a few broken pegs it looks like. Might just need that.
Old Jul 8, 2011 | 05:01 PM
  #660
jefferyss's Avatar
Your hardness has a broken peg..................?
I dont roll that way
Old Jul 8, 2011 | 05:08 PM
  #661
Projekt's Avatar
thats not what you said last time.
Old Jul 8, 2011 | 08:54 PM
  #662
jefferyss's Avatar
It was just the 1 time and I was young and naive lol
Old Jul 9, 2011 | 10:59 AM
  #663
yellow dragon's Avatar
Well boys. Took the yellow daffodil out for some runs at Gimli first time with the mods and Trifecta Tune.Ended up doing 7 runs with my best time being a 15.1941 @ 96.96 mph, 60' @ 2.54s. Had the interceptor set to watch my iat2 and KR3 with the KR3 set to light up if I went above 1.0 well most runs I was at 4.5 - 5.0. So decided to shut it down before I blew it up. My iat2's during the run were at 161*f. So I thinks mes a need a bit more tuning. Also I need to figure out how to set my user rev limiter with this stg 3 tune. So not bashing the tune yet as a tune is always in progress, so far not to disappointed in it. Stay tuned for more updates. Projekt we can to this. Let's get it done. Now to find a new ic pump and front struts. Arrgs
Old Jul 9, 2011 | 11:23 AM
  #664
Bluelightning's Avatar
Got Bewst?
161* IATs is right where i thought you should be. So the pump is working now but it's gonna calf out eventually. But ya your tune sounds too agressive. That's a lot of timing to be getting pulled. Atleast your motor survived lol
Old Jul 9, 2011 | 01:34 PM
  #665
Projekt's Avatar
Ill make sure your taken care of Mike.
This weekend is pretty packed for me but monday will most likely work for data logging and adjustments. I am still searching for that LSJ thread on GMS3.
Old Jul 9, 2011 | 02:52 PM
  #666
So I found in the trifecta stg 3 FAQ thread it states that "trifecta" sets the revs. Bur that's it so far I will keep looking too. I am at the lake so cam only search through my phone so it's killin the battery
Old Jul 9, 2011 | 08:06 PM
  #667
Projekt's Avatar
interesting. thats how i thought to ill have to get on the phone with vince there and really get to the bottom of this once we start tuning more.
Old Jul 11, 2011 | 09:27 AM
  #668
So Jordan are we on for tonight?
Old Jul 11, 2011 | 10:18 AM
  #669
Projekt's Avatar
I Will Probably be working at my other job till Midnight tonight (we are doing store renovations)
However i can still go outside for a bit and upload a adjusted tune to you once Vince get's back to me.
Ill keep you posted via text message today.
Old Jul 11, 2011 | 10:53 AM
  #670
K I am getting your txts but I cant seem to send right now. What vince said about my HE I am not sure I agree with. When we tuned my IC pump wasnt working but it is now. So when we tuned and datalogged I had high IAT2 temps like 140 plus. now in the city I am getting 111 and highway 100-105. I have seen Knock retard up to 7.8 a few times now. So i think we should do another quick datalog now that my temps are more accurate and see what he says. Also please feel free to include me on any emails bewteen you too as well if needed.
Old Jul 11, 2011 | 11:02 AM
  #671
Projekt's Avatar
For sure mike. Like i said in the text message i dont agree with what he said ether.
Here is how to apparently set the GMS3 rev limiter
This.
The rev limiter will increase in 250rpm increments from 6,500rpm - 8,000rpm.
When you want to set the limiter, hold the gas pedal at desired revs and turn the key off. To check the new limiter turn the key back to ACC and slowly depress the gas pedal. It should now read your new limiter.
Do not adjust the limiter above 7,250rpm unless you have upgraded valve springs, and do not adjust the limiter past 7,500rpm w/o NB Shafts.
Old Jul 11, 2011 | 11:07 AM
  #672
fyi jordan now that i have access to a good computer I found the instructions in 30 secs to set the rev limiter on the attached link so I have done it and its set. the link is below and it's titles stg 3 instructions and in PDf format. might be a thing to print of for future clients as it shows how to set rev limiter, octane switch, Nos algorithim etc.. So dont worry about the rev limit anymore lets focus on the knock.
https://www.cobaltss.net/forums/2-0l...er+set+limiter
Old Jul 11, 2011 | 11:08 AM
  #673
Projekt's Avatar
Awesome. Ill save that for sure. Thanks.
Old Jul 11, 2011 | 11:10 AM
  #674
ha too funny we both put it on at the same time.
Old Jul 11, 2011 | 11:11 AM
  #675
Projekt's Avatar
Yeah thats what i thought as well. lol .
