Manitoba SS's 2011 Thread!
Old Jul 12, 2011 | 12:21 PM
  #701
yellow dragon's Avatar
I assume when I do it I am removing the top plug on the stock h/e and leting it run until i see a steady stream of coolant and not it swelling up and out then back in right?
Old Jul 12, 2011 | 12:23 PM
  #702
Staged07SS's Avatar
Administrator
Administrator
If you had opt b I would be of more help to you. I havent bled the stock filler neck setup in years.
but yes, the plug on top of the stock heat exchanger is a bleeder plug.
Old Jul 12, 2011 | 12:27 PM
  #703
Bluelightning's Avatar
Got Bewst?
From my personal experience when I added my dual pass, h/e and option b I didn't really notice any drop in IATs after a pull but found the temps to recoupe much faster. What I meant by that post is people are saying 160* after a pull is too high and that's why it's knocking where I ran those temps for a few months with no issues. When I drove mikes car after you tuned it down the highway the temps were at 150* and went to 190* after a pull. I told mike right then and there something isn't right. He found the pump not to be coming on which is what I kinda thought, smacked it with a hammer and it kicked on. Then started seeing temps like 105* down the highway and 160ish after a pull. But the car still continues to knock like crazy.
Old Jul 12, 2011 | 12:31 PM
  #704
Staged07SS's Avatar
Administrator
Administrator
It's all in how the tune is set up.
GM tunes start to pull timing when IAT2's get to around 140ish.
I know Vince is very conservative with his tunes so I have no doubt in my mind he kept a lot of the fail safes as they are from the standard GMS3 tune.
160*F after a pull is rather high, and if Vince is correct about the 200*F IAT2's than its no question as to why his car is pulling so much timing & seeing KR.
Old Jul 12, 2011 | 12:33 PM
  #705
Projekt's Avatar
hmmm.
and like i told mike. the butt dyno is noticeable that there is power being lost. I hope the bleed works. I really want mikes car fully opperational before i leave for calgary on thursday.
Old Jul 12, 2011 | 12:37 PM
  #706
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by Projekt
hmmm.
I remember when my car had trapped air in the cooling system. For one the car would not drop IAT2's after a pull along with temps toping out at 160*F+. It was aggravating, but once I bled everything my temps went back to normal.
I also felt a noticable power decrease at the top of 3rd as well.
Old Jul 12, 2011 | 01:37 PM
  #707
Well looks like there is a lot of air in the system let it blled for like 20 mins and all it did was bubble. Man I thought I had done a good job on that before.
Old Jul 12, 2011 | 01:44 PM
  #708
Staged07SS's Avatar
Administrator
Administrator
It happens man.
I bet your IAT2's will be much better after a pull now.
Old Jul 12, 2011 | 02:00 PM
  #709
Projekt's Avatar
We can re datalog once your ready mike. I should have some free time tonight hopefully.
Old Jul 12, 2011 | 02:09 PM
  #710
Got Bewst?
Good to hear. Now let's make some powa! Haha
Old Jul 12, 2011 | 02:13 PM
  #711
Projekt's Avatar
Meth? the Drug?
Old Jul 12, 2011 | 02:36 PM
  #712
Got Bewst?
That would explain Vince seeing 200* IATs lol
Old Jul 12, 2011 | 02:39 PM
  #713
Projekt's Avatar
that was tasteful.
Old Jul 12, 2011 | 02:44 PM
  #714
cant do it tonight got a movie date. but maybe tomorrow. I wanna bleed more as I only had a bit of time at work to do it. and also drive around a see if it helps the KR3 if not no sense doing another data log if we still have the issue right?
Old Jul 12, 2011 | 02:50 PM
  #715
Got Bewst?
that was tasteful.
I didn't say it to bash? But mike sees 155* IATs and Vince sees 200* IATs. Still don't get that
Old Jul 12, 2011 | 02:55 PM
  #716
Projekt's Avatar
I wasnt calling it a bash. I said it was tasteful.
Truthfully Mike said he saw 180 IAT2 temps.
I don't think Vince is going to make numbers up. My guess is it peaked somewhere high of 180's-190's and he generalized it by saying "someones iat2 temps hitting 200* is not normal"
Old Jul 12, 2011 | 03:01 PM
  #717
Staged07SS's Avatar
Administrator
Administrator
Is mike recording his IAT2's on the interceptor, or just going WOT and watching them. You will def miss peak IAT2's if you dont record them. I say record IAT2's and rpm at the same time, along with IAT2's & knock. Might help determine where and when the problems is happening.
Old Jul 12, 2011 | 03:03 PM
  #718
Got Bewst?
Ya when I drove mikes car his
temps were 190* but last nite he
did a pull and said it didn't go
over 155. Whatever i just hope this is the problem.
  #719
So how do i record on yhe interceptor. I tried one night but didnt figure it out and then how to play back the recording.
Old Jul 12, 2011 | 03:11 PM
  #720
Projekt's Avatar
Should be in the menu section under record. IIRC. I never used it but i thought i saw it there.
Old Jul 12, 2011 | 04:03 PM
  #721
Just found an online manual so I have learned how. Stay tuned for more as I feel a disturbance in the force. Muhahahahahaha.
Old Jul 12, 2011 | 04:11 PM
  #722
Projekt's Avatar
Thats what i tell my girlfriend everynight...hahahahahahahahhaa
then i sleep on the couch...
Old Jul 12, 2011 | 04:12 PM
  #723
That was tasteful!
Old Jul 12, 2011 | 04:16 PM
  #724
Projekt's Avatar
That was tasteful!
Thats what she ...said?
Old Jul 12, 2011 | 11:22 PM
  #725
Kennyspec's Avatar
after you bled it, how much coolant did you have to add?
