Manitoba SS's 2011 Thread!
Old Jul 12, 2011 | 11:41 PM
  #726
yellow dragon's Avatar
Almost 750 ml.
Old Jul 13, 2011 | 12:03 AM
  #727
jefferyss's Avatar
Fixed....
Originally Posted by Projekt
Thats what he...said?
Old Jul 13, 2011 | 10:44 AM
  #728
So I have been bleeding the H/E System and adding fluid as I go. Temps are staying lower but when I do a hard pull I am still seeing KR3 up wards of 4.5 when i look at it. I have to do a record and see what the peak is. Although I will say I have not seen KR as often as I did before.
Old Jul 13, 2011 | 10:55 AM
  #729
Projekt's Avatar
Okay well thats atleast in the right direction.
If the IAT2 temps are staying down we can then data log and go from there.
Old Jul 13, 2011 | 10:59 AM
  #730
Staged07SS's Avatar
Administrator
Administrator
I'm glad things are starting to get better.
Where are you seeing the KR? In the upper rpm range?
Old Jul 13, 2011 | 11:13 AM
  #731
I will let ya know as i need to find a clear straight road after work to do a few pulls and see.
On a side note Bluelighting found me a new IC pump on the forum for $100 shipped the question I have is would my pump have stopped working before because of all the air in the system and seeing that it has been working well for a few days now should I replace it or put the money towards a DP and Opt B what sould I do first. Arrg decisions!
Old Jul 13, 2011 | 11:16 AM
  #732
Projekt's Avatar
Staged is the right guy to talk to on that one. I have zero thoughts on that.
I will have to meet up with Shane (my other tuner) if you'd like to tune over the weekend mike. Or if you can hold out till monday when i am back in town.
We can do some data logging tonight however.
Old Jul 13, 2011 | 11:18 AM
  #733
I will let ya know about tonight later may have plans with the GF
Old Jul 13, 2011 | 11:20 AM
  #734
Projekt's Avatar
Understandable. I do also have plans with my GF. but i'll put a movie or something on for her so i can step out for a bit if it comes to it.
Old Jul 13, 2011 | 11:27 AM
  #735
Staged07SS's Avatar
Administrator
Administrator
In my honest opinion, I would get your current situation figured out before you add any new mods like opt b or a downpipe. The air trapped wouldnt so much stop the pump from working, but would prevent the coolant from flowing properly thus causing higher IAT2's.
Old Jul 14, 2011 | 12:40 PM
  #736
Well just order a new IC pump so should be in the mail today. Also last night Projekt rescanned the balt and hopefully Vince can tweak it. The kr3 hasnt been as high as it was since I bled her.
Old Jul 14, 2011 | 12:46 PM
  #737
Staged07SS's Avatar
Administrator
Administrator
Good to hear!
Old Jul 19, 2011 | 08:45 AM
  #738
Good to hear!
So Staged question. I now have her bled and the cooling working with a new IC pump on the way. I am still getting knock retard indications. I have noticed that my fuel consumption is out of this world (which I expected a slight increase with the bigger injectors but not this much) and the other day my buddy with a Evo 9 was behind me (like a proper Evo should be LOL and he said I was pouring black smoke out my tail pipe during acceleration. So obviously I am running super pig rich right? Would this cause the KR indications as it is pulling timing to lean her out? Would tweaking the tune help this?
Old Jul 19, 2011 | 08:56 AM
  #739
Staged07SS's Avatar
Administrator
Administrator
You do not pull timing to lean it out....
Being too rich or too lean can def cause KR. Have you ever logged your fuel trims?? I bet they are out of whack for sure. Do you have a wideband? I'm interested to see what your A/F ratio is. If you're pouring out black smoke at WOT I'm willing to bet you're in the low 10's. Something is def not dialed in correctly with your tune.
Now that you will have your cooling system on par, I suggest getting your tune dialed in.
Old Jul 19, 2011 | 09:52 AM
  #740
Projekt's Avatar
We already re-data logged. Waiting to hear back from Vince and hopefully the adjustments corrects this.
Old Jul 19, 2011 | 09:55 AM
  #741
Staged07SS's Avatar
Administrator
Administrator
Ok good!
I hope everything works out. Let me know what Vince has to say when you get the revised tune back.
Old Jul 19, 2011 | 09:59 AM
  #742
Yeah I figured i would need a wideband to tweak it for best results and I am working on that. I just put this up as other stuff i have noticed that may indicate where issues may be. Jordan let me know when we can do that tune after you hear from vince.
Old Jul 19, 2011 | 10:17 AM
  #743
Staged07SS's Avatar
Administrator
Administrator
Yeah, any other info will always help. Hopefully Vince gets everything worked out for you.
Old Jul 19, 2011 | 10:26 AM
  #744
Projekt's Avatar
Will do as always. Hoping i get it back today, Vince was away for the weekend so he did not have time to work on it. But he replied to me yesterday early saying he will take a look at it.
Tonight is a date night with the girlfriend (apparently she likes harry potter? lol) so maybe before hand if i get it today. If not tomorrow night for sure.
I also tried to scope us out a deal on a wideband HPTuners combo. guy wanted way to much
Old Jul 19, 2011 | 10:47 AM
  #745
Ya I am busy tonight too going swimming tonight as it will be 48*C with the humidity today
Old Jul 19, 2011 | 10:57 AM
  #746
Staged07SS's Avatar
Administrator
Administrator
Swimming, date night, this & that.... Jeeze!!
Don't you want your car running right, haha
Old Jul 19, 2011 | 11:07 AM
  #747
Projekt's Avatar
Disregard Women, Acquire Currency.
However for me and mike we have this equation messed up
Old Jul 19, 2011 | 01:34 PM
  #748
hey outta curiosity does any one know what 60# fuel Injectors are in CC's?
Old Jul 19, 2011 | 01:37 PM
  #749
soundjunky's Avatar
I am wondering (yup still lurking here ) if the Trifecta-StageIII is exactly as GM made it - just cracked...
If this is so, then the aftermarket 60# injectors would be the whole issue...
It now looks like I'm taking my Cobalt down there incase anyone cared
Old Jul 19, 2011 | 01:44 PM
  #750
ya but whats the CC's lol
