Calgary - random talk thread
i gotta assume the sensor is not working like it should then. it wont move from 14.6 and 15 for at least 10 mins of running time. or is it possible i have the ground wire to tight?
trifecta is always pig rich so i cant see me being lean. however stranger things have happened
here's where you see a difference between Trifecta and HPT;
with HPT, you have the end tuner sitting right there, observing things such as AFR - even in the case that AFR isn't monitered by the car's ECM;
In the case of the LSJ (as I have understood it), the ECM cannot read AFR - it probably does like older GM ECM's, and looks for a target temperature reading off the O2...
At best, all we can do, is report what we're seeing to see if WOT-Tuning can determin if the tune is reacting the way they want it to.
Mark, we would need to verify that your wideband is owrking, and from what I've read here, it looks like something is not right;
You should not have a huge delay in readings... maybe you have a lose connection somewhere?
Rich up to a point is safe - where as lean can get dangerous fast - Dustin would definately know about this.
Once your wideband appears to be functioning correctly, wee need to see where your readings are on light throttle cruising, and then see where it goes to when you tromp on it - as well as how it appears to act after romping on it...
For a short time last year(?), i was running an optional tune which would suit people who want an atmospheric BOV, iirc it was called something akin to a 'Predictive Airflow' tune - I stopped running it, because I was observing afr's floating around 15.2 - which too me seemed unsafe/too lean.
I'd rather get stomped on by LSJ's, and be able to rely on my car to continue being my DD, rather than chance wrecking something...
Mark, I'm actually leaving town on thursday morning, and won't be back until monday night.
You can call me at home later if you want ot meet up, but unless your gauge appears to be reading/functioning correctly, I would advise not trusting any of it's readings.
i will call you after work jonathan however i wont have my car tonight as it will be over at geoff's. the soonest i can do a datalog session is wed eve after a funeral i have to goto.
overall the car seems to be running good but there are afew things we need to work on, and by in no means am i panicing about the readings i had.
You got it. Lsj only has a narrow band. No wideband running through the ecu. So as Jon said you have to dictate to trifecta your afr for an actually decent afr. Otherwise they'll just make it safe and pour a bunch of fuel in it.
11.8 is a good dd afr that you will still make good power with. That's my recommendation to try to get the car to sit at during a 3rd gear pull.
ok i actually think its working proper and always has. i put some thought into this and i feel its because i am catless. i just went for a drive and 5 mins later i got a accurate reading. i was at 11.8 the first time in a 3rd gear pull. then i did it again and it read 11.3. i feel with having no cat it just takes me going into wot to get a accurate reading.
This may be the only instance where you can say LNF > LSJ
I saw it (I actually helped with hte initial install), it DID work...
Well, at least it did after Steve came over, and wiggled one wire.
Made me feel stupid for getting dirty, and then proceeding to chase down all possible reasons for it not working
I knew that you could datalog with hp pro through a gauge I was planning on doing it with my meth but was just wondering if you can tune the A/F at each 500rpm interval or whatever like you can on the LNF. And I think Mark vs me will see who wins the LNF vs LSJ battle we both have a ported stock poweradder and technically he has more done to his can than I do
for maybe 1 year. i also recall it being absolutely stupid on trying to get a accurate number from.
bite your tongue, no cuss words allowed. yes blue, i do appreciate the help you always have presented. the same goes for jonathan, kevin, and **** face up north hahahaha. you know that sylver guy? without your guys help i may still be on jack stands.
i felt even more like a moron then you i am sure. as you can see i even thought that might be the issue in this case. hahahahahaha
the bottom line is i cant wait to line up with kevin again. we might need to vid that one. that way there is video proof that both cars kick ass.
thanks as always for your contributions here
As dustin elluded, you would need some sort of interface between the laptop running HPT & your wideband - since the ECM cannot read this, there is absolutely NO way for LSJ guys to get this reading from their 'on board diagnostics' port.
I think the whole LSJ vs LNF comes down to supercharged vs turbo it's just what you like both are great but I'll never tell Mark that because I'll always say to him LNV>LSJ oh **** did mark see this??
