Calgary - random talk thread
ok so i may make it for a track night not sure if i will race just yet cause incase i break something want to have the money to fix it lol and ya is there any specific rules as to what has to be done to the car/ safety gear that needs to be worn
this will be the first time i have been racing on a track so i want to make sure i have everything needed first
1) you need to be wearing pants, shirt and shoes - no sandals, and no shorts. (sometimes they voice that they want you to wear a shirt with sleeves, but this one they are inconsistent on - if you bring a hoody ect., you'll be covered.)
2) if your car would pass a safety, you're good.
they are legally obligated to check for:
- battery hold down
- working lights
- working seat belt
- working clutch safety*
- anything that could cause your car to be a safety concern to either yourself or other participants/spectators
they may or may not check for:
- loose seats
- centercaps/trim rings/hubcaps that can fly off
- loose stuff in the interior/trunk**
According to NHRA & AHRA rules, you are not required to wear a helmet unless your (coupe/sedan) car goes 12.99 or faster in the quarter mile.
- Race City for the past couple years has not required participants in "slow" cars to wear a helmet, but they still encourage it*. (Where as Castrol requires it, just because.)
* on their SITE they say you need a helmet, but no one has updated that page in the last couple years - they no longer have helmets to lend out - which is the root reasoning behind no longer requiring them to be worn.
Essentially, if you bag on your car at all, and nothing has broken, odds are you're not going to break anything at the track;
You should be able to get a bit better traction at the track than on the average street (they rarely put down VHT specifically for friday nights) - but unless your car is putting down real power, you should be good;
The only cars that are liable to break CV's are ones running some good hp, full on slicks, and stock CV's.
After that, it's all fun - you may in fact find you will drive your car a bit harder at the track because there is zero fear of speed limits or any other source of inhibition...
There are a couple key things from getting a time slip at the track;
- will give you a quarter mile Elapsed Time and trap speed in MPH (hopefully no explanation req)
- will give you a 60' time; this tells you how good your car hooked up ~ realistically street cars try to hit a 2.0 second 60' or better, but for most, this is VERY tough; as a general rule of thumb for each 1/10th second you can drop your 60', you will drop (iirc)2/10th's on the top end.
- will give you a reaction time; this does not factor into your elapsed time, but will only matter if racing against someone.
- will give you 1/8th mile E/T & mph
The first time I took my GA to Race City I was hooked;
I also found out that night that I had an oil leak, which prevented my clutch from engaging right properly... but still pulled off a 16.6 ~ beating a WRX (solely because he had a terrible reaction time (iirc he had a 15.8))
EDIT:
HERE is a video of my first ever run at the track (taken by the WRX guys friend).
If anyone will need any pointers on running their car, or understand their time slip, I will be happy to help out.
This is great to read!
I hear alot of people complain about Race City, compared to Castrol, but frankly what many of these people miss is:
- that both the tracks in fact get the same kind of prep for friday nights
- track surfaces are the same quality*
- Castrol's lower elevation will yield lower E/T's**
* = NHRA & AHRA have strict guidelines for this which have to be met for a track to be sanctioned; the only year that RC was not a sanctioned track, was a year in which the city council mucked things up just long enough for RC to not be able to get added to the AHRA events schedule; the back (aka: road course) can be a bit scary, but that's not taken into account because NHRA & AHRA care about the burnout area, the quarter mile, and a given stretch at the end of the track for slowing down; and the rules state you're only supposed to do 30kph on the back anyway. As I've understood it, the road course is being (or has been) fixed this year.
** = this will be most evident for n/a cars.
I've heard the tech inspectors can be cooler @ Castrol, but they require everyone wear a helmet, while for the last couple years Race City has gone strictly by AHRA/NHRA rules (helmets for street cars is something that is purely up to the discretion of track management); you only need a helmet if you break 13.0 in the quarter (for a non-convertible); as in you hit 12.9 or faster ~ frankly I like this alot more.
I don`t mind the helmet policy at Castrol, better over safe then borderline when it comes to high speeds and racing. Tech at Castrol is mostly really good, however you can run into the odd retard that wants to inspect a DD like its a NHRA car.
For the newer guys... One of my many 13.8xx runs. Probably by far the closest race I`ve ever been in. I won of course.
http://www.youtube.com/watch?v=2bisYfbC1n0
Last edited by bigrroberto; May 26, 2010 at 03:00 PM. Reason: Automerged Doublepost
I do not have any issue with the above quote, and can better elaborate on E/T differnces this way;
using current NHRA elevation corrections (does not take into account Density altitude, only altitude) lets see some numbers:
Race City: 3280ft (rounding to 3300ft and using those correction numbers)
(sea level correction)
E/T x 0.9601
MPH x 1.0423
Castrol : 2192ft (rounding to 2200ft and using those numbers)
E/T x 0.9744
MPH x 1.0269
elevation difference between tracks: 1088ft (rounding up to 1200 ft as those are the lowest numbers on this chart)
E/T x 0.9874
MPH x 1.0129
Using your own best stock I am going to attempt to show how this looks;
Best Stock Uncorrected: 14.929 @ 100.40mph
corrected for sea level as though it was run at Race City = 14.333 @ 104.647mph
corrected for sea level as though it was run at Castrol = 14.547 @ 103.101mph
So right there you can see that you have to run faster at Castrol (versus RC) to pull the exact same altitude corrected time.
Taking this the next step, lets try to correct between tracks, assuming that you first ran at Race City;
Race City 14.929 @100.40 = Castrol 14.741 @ 101.70mph
Were seeing roughly 2/10ths only using elevation factors if you factor in Density Altitude, it will often be even more extreme.
What am I trying to get at?
This elevation difference is almost entirely responsible for making your car seem to be faster at Castrol.
Ok, lets continue;
I havent a clue what you were experiencing, but I will ask around I for one have never experienced anything of the sort, and I do not recall hearing any of my friends or acquaintances saying anything of the sort
If his was for real, this would make the track plain old unsafe, and (I would hope) not allow them to be a sanctioned track.
Ok, continuing on
Race city needs the parking lot to be fully paved I will give you that.
The fact that the parking lot is gravel is why you were getting gravel in your tires.
Unfortunately between the city council trying to shut it down (to use as a settling pond) and the owner not being interested in really bringing the facility up to the level that everyone would like to see it, I dont think this is going to happen.
As it stands right now, to keep the staging lanes (ect) free of gravel is 100% up to people like you & me who are willing to volunteer to do sweep up ~ or what ever
I sign the insurance waiver upon entry, so I should be able to choose.
Ive raced on what is arguably the premier track in North America (Norwalk Ohio), and even there I wasnt required to wear a helmet unless I broke out of the 13s
ya i am pretty excited to put down a time at the track this year and then improve it throughout the summer
so i am installing my new header tomorrow do ineed any gaskets for the top of it i have the one for the downpipe but do i need one coming from the engine itself
Last edited by kissrocker52; May 27, 2010 at 01:13 AM. Reason: Automerged Doublepost
hmmm...
looks like i might have been mistaken ~ I could have sworn I read it was 12.99 or faster which mandated the helmets!?
http://www.nhra.org/2004/news/june/062202.html
EDIT:
You should have a high temp gasket that fits in between the header & cylinder head...
Depending on the header design, it might be intended to be used with a stock style exhaust manifold gasket.
With my Grand Am, I use a stock exhaust manifold gasket.
Helmet
Drivers in all 13.99 (8.59 eighth-mile) or quicker cars must wear a helmet meeting Snell 90, 95, K98, 2000 or SFI 31.1A, 31.2A, 41.1A, or 41.2A Specs.
EDIT:
Last edited by soundjunky; May 27, 2010 at 02:13 AM. Reason: Automerged Doublepost
whatever happened to the days of line up beside someone, race, if you win you win. if you lose you lose. all this crap with formula's and math ruins racing. just my 2 cents. it ruins something that is intended to be fun. on another note much appreciate graham for saving me from cloraplast hell. i am looking forward to bring his car to another level. lol al bundy if you plan on revenge that lil loss you had there better start buying some parts lol. again my 2 cents.
hey i also noticed my good buddy pickles stop in there lol. how are you man long time no see. cant wait to catch up with you!!!!
I was demonstrating how if you do the exact same run at Castrol you will be faster purely because of elevation;
Nothing has changed, you still line up, race and see who wins.
But seriously;
Race City gets knocked around by people our age because of the misconception that there's something wrong with the track - which imho, there isn't.
I am probably one of very, very few people in our age group who has spoken up about this (I have never heard of anyone else);
if we don't support our track it will be gone, and never come back.
iirc the lease was extended two years, after which there is no plan for a replacement track;
The average age of a Calgary Drag Racing Association member is somewhere north of fifty (if you doubt me, go to a meeting) - and right now, they are pretty much the only people speaking up to try to keep our track going...
seriously?
I was demonstrating how if you do the EXACT same run at Castrol you will be faster because of elevation;
... your right there is no plans for something new. this is a fault of city council, not realizing the importance of the track.
...they should have invested money into the facility. coz of the fact they have lost most of thier major events it has been a down hill spiral for them.
Apparently the only guy on city council who has really lobbied to keep RC open is Ric McIver - if not for him, the track would be closed.
Here's some good info;
Ric McIver is a mayoral candidate, word in the CDRA, is that with him in the mayors seat, there will always be a track in this city...
AFAIK, the whole CDRA is trying to back Ric McIver ~ you might want to consider it too.
Let's stop your quote right there.
E/T x 0.9601
MPH x 1.0423
E/T x 0.9744
MPH x 1.0269
E/T x 0.9874
MPH x 1.0129
Ok, lets continue;
Lets stop there.
Ok, continuing on
The staging lanes at Race City are paved;
Although I agree safe is better, I also think that requiring use of a helmet on a DD on the track is flat out retarded.
E/T x 0.9601
MPH x 1.0423
E/T x 0.9744
MPH x 1.0269
E/T x 0.9874
MPH x 1.0129
Ok, lets continue;
Lets stop there.
Ok, continuing on
My bad, I did I shitty job in my original post there. The post that I was replying to asked which track was better. I should have been more specific when I said that I ran 3 tenths faster at Castrol. You are right, the faster times are 100% the result of the altitude and DA, they had nothing to do with the quality of the prep or track in general.
The rest of my post was about how I thought the Castrol track had a better overall feel to it. The weekend before I came to RC I was at Castrol. When going down the lanes up there they feel almost like glass they're so smooth. The ones at RC are good, but they didnt feel AS good as Castrol. Are they unsafe, no probably not, will they effect times, I doubt it, but they just didnt feel as nice. I had the luxury of driving them back to back and that's what I remember them being like. I'd have to come down to RC again to be sure on this as its been 2 years since I was last there.
EDIT:
@ Steve (aka:'outtamymind')
Considering that you were talking about building another engine, you might want to consider joining in, or at least following this thread;
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/2-4-black-sheep-engines-216482/
Early on when I came here I posted up trying to see what kind of power the LE5 was able to make, and was (no offense) rather underwhelmed - I joined in on this discussion because it seemed legit, and I figured I could help continue it along.
