DevilsOwn Alcohol Injection DevilsOwn Alcohol Injection is a Supporting Vendor of cobaltss.net
Contact: devilsown
DevilsOwn 2.5 gallon sumped tank
Old Apr 21, 2010 | 04:00 PM
devilsown's Avatar
This 2.5 Gallon tank from Devils Own is the first water-methanol tank with a built in sump and fluid control baffle. This eliminates the pickup being uncovered during sprinted driving. Because of the tanks quality design and it featuring a real sump in it, you can run the tank down to approximately 1 qt of fluid before uncovering the pickup. This tank is made with 1/4" thick HDPE, which is the same material and construction that is commonly used in manufacturing fuel cells.
Dimensions are 8" x 13.5" x 8.5". So It's best suited for trunk placement.
This tank features a 2 1/4" opening for easy fill up. This tank can be used for any alcohol water mixtures. It's 100% methanol compatible. Tanks design also allows for proper ventilation for the pump heat.
I'd like to offer a Tank Upgrade to CobaltSS members. $75+shipping. That's $20 off our regular price and I think you'll be impressed with the quality of this tank.(note that tank alone does not come with pump)
= $20 off :flamingde
On all new kit purchases with the new tank, we will knock off $20 on the tank and give you free shipping.
+ = $20 off plus free shipping!:flamingde
Feel free to place orders over the phone and make sure to ask for the CobaltSS members tank upgrade discount.
Give me a shout:
Chance @ Devil's Own
sales@alcohol-injection.com
405.470.4356
Old Jun 18, 2010 | 09:32 AM
Gunney_07's Avatar
order # 6668
1 x 2.5 Bar Stage 2
1 x Nozzle Mounting Adapter
1 x 2.5 Gallon and float sensor
This is for a 09 ss turbo, any advice as how to mount and set up would be greatly appreciated.
Old Jun 21, 2010 | 03:05 PM
Gunney_07's Avatar
Old Jun 22, 2010 | 11:23 AM
devilsown's Avatar
Tank, you will want to mount that in the right rear corner of your trunk. Then wrap the tubing to the left and run it down in the back corner. Be sure to put some bushing between the sheet metal and the tubing. Then just run the tubing under the car till the engine bay. Then just run it up to the charge pipe and drill a hole in the rubber coupler and attach the nozzle to it. Be sure to put a dab of lock tite on the nozzle mounting adapter.
Old Jun 22, 2010 | 01:22 PM
Gunney_07's Avatar
thank you for the info cant wait to receive!
Old Jun 28, 2010 | 08:57 PM
Gunney_07's Avatar
This 2.5 bar controller that came with the kit, will it work on the 3 bar gms1 sensors? Also the 2.5 controller only goes to 20 on the dial. Just on my stage 1 tune i spike 23-24 and hold 21psi. Will this controller work or can i swap it out for another you guys have?
Old Jun 29, 2010 | 12:23 PM
Gunney_07's Avatar
bump.....
Old Jun 29, 2010 | 10:14 PM
devilsown's Avatar
if you are going to hook up the controller to a 3 bar map sensor you will want our 3 bar controller. if you have the factory map it should be a 2.5 bar. the 2.5 bar map only works up to 22.5psi. Anything over that and it just sends the same signal.
yea we can swap it out for you if you recently bought it from us or a dealer. if you do have a 3 bar map sensor.
Old Jun 29, 2010 | 11:25 PM
Gunney_07's Avatar
yes, i would like to swap it out for the 3 bar. It just came last friday the 25th and is still in the plastic wrap. Now i know i have to pay to ship back to you but do i also have to pay to come back to me? Also how do you prefer it shipped (carrier and such)?
Old Jul 1, 2010 | 03:02 PM
devilsown's Avatar
usps, and ups works fine. Yes we would need you to cover shipping back, With its size you can put it in a usps envlope and will cost less than 5.00 each way.
Old Jul 1, 2010 | 04:36 PM
Gunney_07's Avatar
I'll send it out tomarrow! For payment since you already have my debit card info can you just set me up a bill on my online accout and i'll pay it online?
Old Jul 1, 2010 | 07:27 PM
Pedobear's Avatar
when does this sale end
Old Jul 1, 2010 | 07:31 PM
Gunney_07's Avatar
i think it's already over, because i did 'nt get the free shipping.
Old Jul 1, 2010 | 07:32 PM
Pedobear's Avatar
gawt damnit
Old Jul 1, 2010 | 07:40 PM
Gunney_07's Avatar
lol, the kit is nice.... I got the tank upgrade with a stg 2 kit. The tank is very robust, Has internal baffles to keep from sloshing around to uncover the pump tap. Also tank comes with a lvl sensor that hooks to the controller for safety measures. Very Simple to put together for the most part, wiring will be the hardest and that’s not that difficult.
Old Jul 1, 2010 | 07:56 PM
Pedobear's Avatar
i already had the kit just upgrading to a bigger tank. i meant to grab it cuz the 20 bucks off shyt
Old Jul 1, 2010 | 08:20 PM
Gunney_07's Avatar
It's probly still worth it if you ahve the trunk space
Old Jul 1, 2010 | 11:30 PM
Pedobear's Avatar
i do, but i prolly wait till i really need it and see if another discount comes along i can do without i already have one but smaller
Old Jul 5, 2010 | 12:00 PM
devilsown's Avatar
We dont' see/ or even store peoples cc info. It goes directly from our site to the cc merchant and then a yes no back. I don't want to be responsible for it. just call in tuesday and we will be in.
Well the new guy didn't put a end date. Lets just put it as july 9th.
It shoud have had an end date posted but i guess it didn't email me and i will credit you fro the shipping.
Old Jul 5, 2010 | 01:15 PM
Gunney_07's Avatar
oh, ok i will call when the ups tracker says it made it. And thanks for the credit i had no beef, but thanks!
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
riceburner
Sep 26, 2015 12:57 AM
