2011 Drag Racing Times
for me:
car 4152: 14.562@96.63 w/ 2.297 60'
NWAE Cobalt: 2.2l 5spd: Intake, intake mani, tb, 32lb injectors, shaved cyl head (higher compression), 78lb valve springs, stg 2 cams, header, dp, catless, exhaust, lowered, tuned, weight reduction, street tires
time slip:
vid (you can read most of the number but its backwards on the window :P): YouTube - ‪cammed 2.2 cobalt 1/4 mile 5-14-11‬‏
time slip:
On the other ticket it said 104 or a 14.3 And the other guy that drove this car did a 13.9 was at 105. I just didn't spin that time is all I guessed. Idk everyone else's times and speeds were right on
It looks like a track error too because the guy next to you lost 3 MPH after the 8th. You also both did the 1000Ft in 0 Flat which makes you at more than light speed
I am going to order a GoPro HD for the Car to get some good footage instead of my iphone. I am sure some of you have seen my vids and i was always pretty gentle on street tires out of the hole. I must say leaving on slicks was sick with the cobalt i was launching at 4k on the old M62 and hooked so hard i almost missed 1st gear each time, no spin just dead hooking it.. Going to be different on the turbo but will still be launching the lsj with the wotbox. Will start at 3 and work my way up. Gonna be fun for sure.
Yeah i know its going to be different on the turbo for sure. Sure i will find my sweet spot eventually. 5k Launches are def going to be fun for sure. Guess we will find out . Never owned anything turbo so this should be interesting.
stock cooling might be getting you too. Do you have a slip so I can put you at the top of the LSJ's?
It's not the cooling. Temps are fine, I have coil packs that are bad. It misfires top of 2nd and all of 3rd now. Just doesn't accelerate at all when it's in boost. They were acting up last year, and they finally bit the bullet this year completely.
I went a lot faster last year, not worried about this shitty time slip.
for me:
time slip:
time slip:
What does your car weight? Do you know? Approx?
