Drag Racing Kindle Racing and Dalcorp Racing
New Drag Times Thread
Old Jun 16, 2013 | 10:05 PM
  #251
EXsoccer1921's Avatar
That's put together nicely. Mind if i put it on cobalt nation? What's your name again.
Old Jun 16, 2013 | 10:13 PM
  #252
cmiller8006's Avatar
Something else to try is to rev 1rst out to redline and not nls since the zfr spools so fast. It looks like you are way short shifting and bogging hard into second. Could get you a few more tenths
Old Jun 16, 2013 | 10:15 PM
  #253
Also nls forth, it will be ok, and I have the n2mb wot box.
Old Jun 16, 2013 | 10:25 PM
  #254
2010SS's Avatar
feel free, chris connor 'dos' on facebook
Old Jun 16, 2013 | 10:28 PM
  #255
2010SS's Avatar
yea i used to run out first gear, but it didnt seem to change anything 60' 330'....
im still experimenting with the zfr, this was the first time out with ethanol and zfr. i also used to nls on stock turbo but could produce the same times not doing it..
will try all of the above when i get out again. I also want to try some suspension stuff to try and knock off a few tenths
Old Jun 17, 2013 | 12:31 AM
  #256
well you picked up a full second(from your signature. i know you've gone 12.00) going from the stock turbo to the zfr and slicks. that's something to be proud of.
Old Jun 22, 2013 | 12:01 AM
  #257
ShawnW117's Avatar
well I can't really compare to you guys but I just went for the first time tonight and managed to make a 13.3 second pass at 110 mph. I'm on bald stock conti's with 36,000 miles and a slipping clutch. My first run ever was a 13.482 at 104 and then I made a couple 13.6 passes at 111. Pretty much fully bolted besides catback and intercooler. HPtuned by byt. I am definitely looking forward to going again soon.
The left lane was a late 90's Camaro SS with big slicks. Not really sure what happened there but I know he did a huge burnout haha.
Old Jun 25, 2013 | 02:53 PM
  #258
shasam1721's Avatar
ok so I wanna ask. wat does CM mean. for example this guys lsj. 2. zrated89 12.07@117 I/H/DP/CD/CB/CM/WI/T/DS/TVS/2.7
maybe meant to put IM for intake port?? well I wanna know how to get to this guys level with a somewat similar setup. I have the AIS WI system trunk mount. going to be using a different supercharger tho. i'll let the cat outa the box in a couple weeks here, but yea I have I,H,DP,CD,CB,WI,T, and some DR's coming soon. im guessing driver mod for such a good time?? thanks guys.
Old Jun 25, 2013 | 02:56 PM
  #259
shasam1721's Avatar
your mph is pretty good but your time definitely needs some work if your making 110mph passes. what size tires are you running? are they street tires? I have 245 Pirelli's on my lsj. but im nervous about breaking axles with a launch. buying some extra napas here asap.
Old Jun 25, 2013 | 03:18 PM
  #260
crasycowi's Avatar
Forum name: crasycowi
Car type: LNF
ET: 13.79@107.02
Mods: I,DP,CB,IC,CP,T, ST225/40/18 conti
clutch wont hold the power so had a lot of slipping in 3rd
Old Jun 25, 2013 | 03:42 PM
  #261
ShawnW117's Avatar
they are bald stock street tires which are 225. I know the car has more left but I definitely need to fix my tire and clutch situation first
Old Jun 25, 2013 | 03:52 PM
  #262
shasam1721's Avatar
Yup good idea
Old Jul 6, 2013 | 01:24 AM
  #263
Riceburner
Car type: LSJ
ET: 13.975@100.12
I, H, DP, CB, T, 225/60/16DR. 2.8M62, WI, HE, DPE, OPTB, SM
...2step, NLS
80° and 45%humidity track stuck real good
3rd gear gets robbed by heatsoaking i have a small leak on the manifold endplate
Proud of my 1.9 60' though!
Old Jul 6, 2013 | 01:41 AM
  #264
c130aviator's Avatar
good job on the 60 rice
Old Jul 6, 2013 | 01:47 AM
  #265
you have a nice 60'. you could probably pull a 1.95 or better, but still a 2.0 with those mods you should be much lower than 13.9.
what does your shifting look like? Stu went 12.98@109 and then 12.75@108 with dr's on 2.85" 60s intake head dp catback trans mounts ingalls opt b.
12.98 run had a 2.06 60'. 5.61 330'. 8.47@86 1/8. 10.92 1000'
12.75 run had a 1.93 60'. 5.39 330'. 8.23@86 1/8. 10.68 1000'
your 60' is there. the mods are there. but something is missing.. shifting? tune?
oh and yes these are the drag radials i still have on my car that i'm still pulling 2.0 60's with. 5 years later... hahah
Video Link: http://www.streetfire.net/video/hatrickstu-goes-12s_195722.htm
Dude sorry never saw this post. Thats crazy i know my car can run so much faster!
I think heatsoaking is my main issue. 1st gear hooks up and goes, 2nds alright then third is like thsthspstpst.
Im on a james tune i got back in january... Car runs pretty good... I hear something ticking in the bay though... Knock knock knockin on heavens door?
On these 13.9 runs i row through the gears pretty good, no lift shifting. Im not hiting the rpms perfect; i usually shift from first a bit prematurely because 1st revs so fast
On roll races i often hang with mid to high 12's low 13's cars. Whadafuk?
Old Jul 6, 2013 | 01:48 AM
  #266
Thankyaw
Old Jul 6, 2013 | 02:16 AM
  #267
Get a tune. You're trapping bone stock mph's and a full second slower than what you should be going based on the 60' and mods.
Old Jul 6, 2013 | 02:17 AM
  #268
And get rid of the strut bar. It's only adding weight.
Old Jul 6, 2013 | 02:23 AM
  #269
I gotta get a proper wideband setup and then go get dynotuned by omiotek. Just money
I like the bar for looks. its ok more weight over the front wheels right? I dont carry a spare tire too
Old Jul 6, 2013 | 02:51 AM
  #270
I meant that sarcastically. As in besides looks it doesn't do anything lol. When are you heading over to PWerks?
Old Jul 7, 2013 | 01:39 AM
  #271
Yeah i know its as useless as the spoiler is
Anyway.. Hoping sometime in the next month or so!
Old Jul 9, 2013 | 10:18 PM
  #272
Wert842's Avatar
12.97 @ 113. Still getting used to the power and whens best to shift.
T, I, DP, CP, IC, ZFR, 93, Streets
Sent from my Samsung Galaxy S4 using CobaltSS
Old Jul 14, 2013 | 07:35 AM
  #273
iameric's Avatar
Forum name: iameric
Car type: LNF
ET: 13.2233@110mph
Mods: i, cd, cb, t, st, ic, cp,
Old Jul 14, 2013 | 08:21 AM
  #274
Wert842's Avatar
Originally Posted by iameric
Forum name: iameric
Car type: LNF
ET: 13.2233@110mph
Are you running E?
Old Jul 15, 2013 | 07:12 AM
  #275
iameric's Avatar
Originally Posted by Wert842
Are you running E?
Nope, no E. just pump 94 octane
