Drag Racing Kindle Racing and Dalcorp Racing
What the hell is wrong with my time????!!!!
Old Jun 8, 2010 | 02:28 PM
chris88z24's Avatar
Next time ******* blast this song when you're going down the 1/4:
http://www.youtube.com/watch?v=3fa4HUiFJ6c
In regards to your tune
Old Jun 8, 2010 | 02:40 PM
Doc's Avatar
Doc
Originally Posted by SS4ME
Wow. I ran a 2.3 60fter once and still managed a 14.0@103. I think you already have your answer.
bingo....driver mod 1.0
Old Jun 8, 2010 | 02:53 PM
roadrage06's Avatar
You'ze got screwed!
I ran a 13.9 @106 on a ST2 w/2.9 (231hp, 219tq)
And I had approximately 260fwhp with my 2.8, 60's, h/e, midlength header/dp combo, exhaust, and tune. (I say approx. because it was pulling timing up top because of a bad water pump -- actual recorded dyno was 249)
Old Jun 8, 2010 | 03:01 PM
rnjmur's Avatar
You really need to get a good tune. Even a "safe" tune should net better numbers than those. I had a 2.95" pulley, GMPP exhaust and header and a dual pass IC and was putting down 235 whp with a DD "safe" tune and could hit 14 consistantly at the track.
Old Jun 8, 2010 | 04:56 PM
jonnymerk's Avatar
Tune and practice maybe help. I ran crappy times first time at the track with my turbo swap. Also poor tires will only hurt your times.
Old Jun 8, 2010 | 07:22 PM
blake05SS's Avatar
the track was 132* when i ran and we had to wait in line for like ten min so pretty sure i was heatsoaked
Old Jun 8, 2010 | 11:03 PM
Neddy06SS's Avatar
Originally Posted by hawkssoccer11
R/T: .469
60: 2.328
330: 6.433
1/8: 9.735 @74.28
1000: 12.603
1/4: 15.01 @93.48
This is coming to you as my first post. Drag racing is a violent animal that is hardly understood but widely tampered with. Drag racing is 10% car and 90% driver. I have seen 500hp cars lose to 150hp Civics. With that being said, I can tell you (due to my 20 years of racing experience) that your numbers are spot on for whomever was driving. Granted your mph is quite low (1/8 and 1/4) and even with a 1.9 short, you would only be running a 14.4 ET. What tires did you run? What psi? How much weight was in the car? Were you powershifting? What was your launch rpm? Believe it or not, weight is the leading killer of good times at the track. But without traction, hp means nothing.
-Mike
Old Jun 9, 2010 | 12:22 AM
EXsoccer1921's Avatar
-Mike
yeah uhmmm.....stock, these cars are going .8 seconds and 7mph faster. his run is not spot on.
Old Jun 9, 2010 | 10:18 AM
rnjmur's Avatar
Agreed. Even if he is/was a crappy driver, he should have still trapped close to 100mph. The only way he could have trapped that low with his mods is either a poor tune or he short shifted every gear.
Old Jun 9, 2010 | 02:56 PM
ralliartist's Avatar
it is NOT your 60' time causing this. on my 2.8" setup i was hitting 2.3 60' times yet i was running 13.70s and never trapped below 105. your tune sucks, or you're heat soaking really bad and the car is pulling timing. and seeing that you're 1/8 mile is roughly 5-6mph off the norm for a solid run with your mods. and your trap speed is about a full 10mph off...it'd say its a combination of both.
it was raining, 100* air temp and only 114* track temp?
It had just rained the day before and a lot of roads were still flooded. I had to detour off I29 just to get to KC. The humidity was pretty damn high.
Old Jun 9, 2010 | 03:08 PM
  #36
i'm just givin you ****, cause 100% is raining lol
Old Jun 9, 2010 | 03:12 PM
  #37
Actually, 100% humidity is when the atmosphere is holding the maximum amount of water it can. At this point, fog and dew start to form. If that air were too cool further, then it could not hold that moisture in vapor, and it would precipitate out as rain.
Rain NORMALLY results from 100% humidity, but not all the time. When I was stationed in Guam, we would see 100% humidity all the time and yet not get rain.
But yes, I was exgerrating slightly about the weather on my track day when I was stock.
Old Jun 9, 2010 | 04:53 PM
  #38
jonnymerk's Avatar
"Thanks Dan Rather now lets check the local weather...back to you...Tom?"
Old Jun 9, 2010 | 04:56 PM
  #39
Hey lady, you wanna watch Air Bud?
Old Jun 9, 2010 | 05:01 PM
  #40
jonnymerk's Avatar
Is that the basketball or the football one?
hacadacalopolis
Oct 28, 2015 06:09 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
roth
Sep 26, 2015 12:16 PM
