Broken Axle! Fixable?
Old Jul 8, 2013 | 10:10 PM
NGalaxyTimmyo's Avatar
I noticed some wet spots under my car about a week or two ago. I manage to figure out it was coming from somewhere around the trans. I figured since I was about to put in a new clutch, might as well check it out then. So after I dropped the trans this is what I found. The wet spot was some of the grease leaking out of the joints in the axle. When I removed it from the trans, this is what I found.
This is the same thing that happened to my other stage 2 axle after I blew my engine a couple years ago at the track. I threw a stock one on that side, but now I'm not sure if I still have my other stock one.
I haven't driven the car in almost two years until this past month. I'm in the process of returning it to stock to sell it. It didn't leak before I put it away, and I haven't really ragged on the car since I got it all together again.
Either way, should I just order a new stock axle, or should I repair this one?
Old Jul 9, 2013 | 09:38 AM
mrbelvedere's Avatar
you should post this in the drive train section not the performance section
get a new axle remove the old let it eat
Old Jul 9, 2013 | 09:42 AM
Staged07SS's Avatar
Administrator
Administrator
Thread moved.
Listen to MrB.
Axle replacement is cake, and much easier than trying to repair the axle its self.
Old Jul 9, 2013 | 10:27 AM
especially considering the price
Old Jul 9, 2013 | 10:57 AM
Hobbitjones's Avatar
Go to napa buy axle. They are lifetime warrantied and cheap
Old Jul 9, 2013 | 11:51 AM
Staged07SS's Avatar
Administrator
Administrator
This. The NAPA axle is also a little thicker than the stock SS/SC axle.
Also, the bellows in the axle boots are larger so less chance of them cracking/leaking.
Old Jul 10, 2013 | 12:07 AM
wayfarer's Avatar
I had the same thing happen to a Driveshaft Shop (DSS) level two axle-- they repaired it under warranty
Old Jul 10, 2013 | 12:10 AM
Powell Race Parts's Avatar
put a new axle seal in as well. that way it wont be leaking when you sell the car
under 8 dollars from timken
Old Jul 10, 2013 | 12:12 AM
What about good old autozone.
Old Jul 10, 2013 | 12:19 AM
Napa sells replacement ss axles i believe. Ive heard somewhere theu are 1 mm thicker than stock as well. Might just be a myth but they are cheap anyway so wirth checking out
Edit: staged said it
Old Jul 10, 2013 | 07:09 AM
Staged07SS's Avatar
Administrator
Administrator
Yep, no myth.... measured mine before I installed it.
Old Jul 11, 2013 | 06:28 PM
Thanks. I ordered a new one a few hours ago, and they said they would have it in the morning. Time to change the trans fluid (since I still have the trans out. Damn rain stopped me the other day. Never had water rush into my garage before....), and finish up the clutch install.
Wayfarer, how did you go about getting them warrentied. I have another LSJ I could throw these on in the future.
Old Jul 11, 2013 | 11:06 PM
wayfarer's Avatar
not exactly sure. I bought them second hand, so when I discovered it was broken, I contacted the seller. He got the authorization, I just shipped it to them
chefhhr
Oct 26, 2015 10:36 PM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
