View Poll Results: What gear failed on your F35?
First gear
18
11.92%
Second gear
64
42.38%
Third gear
50
33.11%
Fourth gear
7.28%
Fifth gear
31
20.53%
Reverse
22
14.57%
Multiple Choice Poll. Voters: 151. You may not vote on this poll
The "Broken F35 Transmission" thread
hahaha my transmission is probably about to pop. While sitting at a dead stop and put it into frist i hear a horrible whining/grinding/scratching sound. So I try every gear and they all make it. So idk if it's the transmission or my tob is about to implode lol. It also gets hard to get in and out of gears at times
That's what I'm hoping since it does it in every gear it sounds like it might not be engaging fully or maybe the clutch rod is bent. Cuz if I sit there not in gear and no clutch pushed in I just hear the normal tob chatter. So I tried to pull out and it was real stiff and the noise starts. So I pushed the clutch in and out like 10 times and it was easier to get in and out of gear but still made that noise. wonder if i lost pressure or something needs rebleed
^ yeah thats air in the system. Whenvever you have to pump the pedal to build pressure its air in the lines. Try bleeding it first, if it keeps going back to the issue you have a hole in the lines or a busted slave/TOB or master cylinder.
well it still makes the noise so i doubt i got a hole in the line but i noticed if i sit there and do that it gets easy to put into gear (sometimes) Question is how long am i able to drive it hahaha I got to get it to my buddies shop for the lift
I have an 08 SS TC. The car is at 101, 000 miles. A lot are highway...but whenever I shift...no mattet how smooth...it will make a scratchy sound and it seems like 2nd slips sometimes? I already replaced clutch...its on about 300hp/370tq. Any suggestions?
I’m calling bullshit! I know for a fact that your car is not at 400wgp for one that stock clutch would be cooked from the dyno pull alone. (Ask me how I know) just because you have a cold air intake doesn’t make your car 400 whp. Post the picture of dyno graph for proof next time.
