clutch bleeding HELP!!
So did they actualy inspect it to see if it was leaking or if it wasnt tightened all the way down. One thing i know is if the fluid get contaminated itll cause the slave to go bad because the seal. How were all you guys installing and bleeding. Did u. Use all new fluid
That I am unsure of. Install and vacuum bleeding was performed by a mechanic, not me. The clutch was fine for a couple weeks, then it started shitting on me.
I'll find out tomorrow if I gotta pay. They told me it was under warranty, but I didn't exactly speak up either. We'll see if the tech says anything. I won't be surprised if I gotta pay, it is aftermarket after all.
#36
Good. . .........Did u suck fluid in the t.b and make sure there was no air in it and the installing the hose ect when tranny is installed.. And using vacuum on it.... But im going back to ky for a prototype 8 puck i was thinking of mixed pads kevlar and ceramic on the same side and ect.
#37
I payed for the install and will never let anyone but the dealer or myself work on it again. The tech at the dealership really knows his ****. As soon as he dropped the tranny, I got a call about my stage 3 and the slave that wasn't oem.
#39
Well it looks like im going to be doing the same thing cause the dealer replaced the m.c. and vacuum bled it but it did the same thing. So I ordered a gm slave the other day.
#42
I have issue with finding the dam leak. Your blessed to know, mine is ghost leak somewhere in the system, I'm crying about finding it. Somehow she bled enough to suck air into the clutch, barely held the brakes.
GM should recall these POS parts they give us, I feel jilted. Need a ZZP Brake Line Kit upgrade option.
