Clutch help!!
Old Oct 14, 2019 | 09:17 PM
Hudie72's Avatar
Clutch help!!
I have a 2006 ss/sc that I recently replaced the clutch with a Luk clutch kit. I also replaced my clutch master t.o.b and line also replaced metering block all with gm parts and am having issues with bleeding it. I have taken the trans out 5 times and cannot figure out what is going on. I have tried pressure bleeding and manual bleeding. When I vacuum bleed the fluid just rises up in the system and does not ever go back down. Any advice would be greatly appreciated
Old Oct 14, 2019 | 09:36 PM
exninja's Avatar
I can't tell what your problem is. Are you applying vacuum to the overflow tank and the fluid in the tank rises, but you're not getting any clutch pressure?
Old Oct 14, 2019 | 09:56 PM
Hudie72's Avatar
I am adding vacuum to the reservoir and the fluid level rises but it does not remove any air am I supposed to pump the clutch with vacuum applied?
Old Oct 14, 2019 | 11:09 PM
exninja's Avatar
Yes, slowly push the pedal all the way down and slowly release it 5-10 times. It should take 5 seconds to push the pedal all the way down, then 5 seconds to bring it back up. You also need to keep vacuum on it for a while. There should be instructions on crateenginedepot.com
Old Nov 5, 2019 | 06:24 AM
Hudie72's Avatar
Finally fixed
Turns out I had a faulty pressure plate. It was a brand new luk clutch kit I purchased from rock auto. The pressure plate had two bent teeth on it that wouldn’t disengage the clutch cost me another 270 for a clutch but I’m back on the road again!!
Old Nov 5, 2019 | 08:40 AM
jdbaugh1's Avatar
They should have warrantied that
etnies
Dec 15, 2012 06:57 AM
TonyTuna
Feb 11, 2012 02:23 PM
roderick
Aug 3, 2011 05:41 PM
wtpcobaltss
Dec 31, 2010 10:31 AM
bmontegari
Apr 15, 2010 10:04 AM
