clutch pedal queston??
Old Sep 20, 2011 | 11:45 PM
gumby3558's Avatar
I'm trying to buy a 1999 3.8l 5 speed camaro. It has a hydraulic clutch in it. the clutch was replaced like 5000 miles ago. the clutch grabs in the right spot and i doesn't slip but the pedal doesn't have alot of tension behind it. like when you are lifting up on the pedal it doesn't push against you foot. i don't know if this is normal or not i just feel awkward. i realize this is ot a camaro forum but this is the only forum i belong to so any help would be appreciated!
Old Sep 21, 2011 | 12:00 AM
Sharkey's Avatar
could be a number of things. it might be a weak clutch, or just a cheap one. might be a worn clutch fork and pivot ball. i doubt its going to be hydraulics, pedal feel is generally a mechanical thing, providing the clutch grabs in the correct spot.
Old Sep 21, 2011 | 03:06 PM
gumby3558's Avatar
Is there any way that it could be air in the system?
Old Sep 21, 2011 | 10:10 PM
Sharkey's Avatar
if there is air in the system, or there is a faulty hydraulic component the clutch will grab very close to the floor, if your even able to get it in gear.
Old Sep 21, 2011 | 11:05 PM
gumby3558's Avatar
Makes sence I was looking online and there is clutch pedal return spring that looses tension and or falls out
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
