Clutch prob
Old Apr 14, 2013 | 10:56 AM
derekhollister's Avatar
Clutch prob
Trans wount mount flush against engine So set the trans down and pulled te pressure plate and clutch down and thought I'd see if the clutch would slide on the trans shaft so I tried it the right way first(thick part towards trans) wouldn't go on at all so I flipped it(thick part towards flywheel) and is slid right on.. So does this mean ttr sent me the wrong clutch?
Old Apr 14, 2013 | 11:22 AM
JapEatr's Avatar
South Central *********
Check for burrs on the splined hub of the clutch
Old Apr 14, 2013 | 11:57 AM
I've tried it a few times and the clutch wount slide on
Old Apr 14, 2013 | 01:41 PM
TurboTechRacing's Avatar
This or the input shaft.
Old disc could have caused wear on your trans input shaft. New disc is to new/specification, fits snug as it should once it is slid on.
Old Apr 14, 2013 | 02:01 PM
joeworkstoohard's Avatar
dumb question, you did lube the shaft, right?
generally, the right amount is a little tiny bit, then wipe it with a rag
Old Apr 14, 2013 | 02:22 PM
Yes lubed it and it would only go on the shaft backwards
Old Apr 14, 2013 | 02:48 PM
JapEatr's Avatar
If it slids on, it should slide thru
Old Apr 14, 2013 | 03:16 PM
Ya but it isn't
Old Apr 14, 2013 | 08:23 PM
It only slides on the wrong way
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
