clutch replacement
Old Jun 19, 2008 | 04:07 PM
lightinbalt's Avatar
clutch replacement
so i just go my exedy clutch today. i need to know if anyone that has replaced there clutch have replaced there throw out bearing.
Old Jun 19, 2008 | 04:09 PM
Orange07ssinfl's Avatar
I replaced the throw out bearing/release cylinder its worth the extra hundred bucks so you dont have to pay labor again if something happens to it. mine was fine but i replaced it anyway.
Old Jun 19, 2008 | 04:12 PM
i am doing the replacement myself, i was asking because gm says that the throw bearing is apart of the slave cylinder.
Old Jun 19, 2008 | 04:14 PM
joeworkstoohard's Avatar
it is, it is all one part. word of advice, use an OEM part, not an aftermarket one.
also, bleed it the normal way, that vacuum method seems to ruin them.
yes its all in 1 piece its easier to do it all at once you change the flywheel that piece is right behind it.
Old Jun 19, 2008 | 04:16 PM
i am not replacing the flywheel because the car does not have many miles at all, and isnt the throw out bearing infront on the pressure plate...
Old Jun 19, 2008 | 04:17 PM
correct, you don't remove the flywheel to get to the throw out bearing.
Old Jun 19, 2008 | 04:18 PM
mybe i am backwards on that i believe it is
Old Jun 19, 2008 | 04:20 PM
that's what it looks like on the trans.
Old Jun 28, 2014 | 10:25 AM
PurpleHayze_98's Avatar
Do you know the thread and length of those bolts?
Old Aug 25, 2014 | 02:25 AM
C Vanciu's Avatar
M6x1.00 roughly 25mm
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
