Does Anybody Problems W/ Axel Seals?
Old Mar 13, 2008 | 08:04 AM
mperez's Avatar
I NEED HELP. IM HAVING PROBLEMS W/ MY AXEL SEALS. THIS WILL BE THE THIRD TIME I HAVE TO REPLACE IT IN 6MTHS. ANYBODY HAVE ANY ADVICE?
Old Mar 13, 2008 | 09:46 AM
qwikredline's Avatar
do you mean axle boots? Should not be a problem, depends what you are doing with the car....
Old Mar 13, 2008 | 09:52 AM
mperez's Avatar
Went To The Dealer And There Saying Its The Output Seal At The Axel Thats Connected To The Case.
Old Mar 13, 2008 | 10:06 AM
thats bizarre should not happen. Are you experiencing a lot of power hop?
Old Mar 13, 2008 | 11:39 AM
mperez's Avatar
Not Since I Put My Torque Dampner. Just Started After I Puts Mods To The Car.
Old Mar 13, 2008 | 12:24 PM
to much oil in the transmission? thats easy to do, if it is not a measured fill. F35 SC Fluid capacity (approximate): 1.7L / 2.0 us qt ( dry ); too much oil and it could leak out as pressure builds up there is a vent but its hard to find. Unless its leaking from the seal at the intermediate shaft on the passenger side, in which case the housing could be damaged. Almost impossible to diagnose this stuff via internet...
Old Mar 13, 2008 | 12:58 PM
mperez's Avatar
Thanks For The Info. Ill Look Into That.
Old Mar 13, 2008 | 01:27 PM
Archie's Avatar
When I used to work at a tire shop, I hated it when those things were torn. The owners would drive around for 6 months to a year, and not even know it had happened.
I hated it cuz the grease would spray all over the inside of the wheels, and then I go and grab the inside of the wheel and get a handfull of grease. It happened twice, and from then on I always wore gloves.
I'm glad you caught it soon. Good luck with getting it fixed.
Old Mar 13, 2008 | 01:43 PM
mperez's Avatar
Thanks, But I Think Its The Housing
Old Mar 13, 2008 | 01:54 PM
if you are out of warranty pm me i may have an intermediate shaft if you need it..
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Trav3480
Sep 28, 2015 02:46 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
