Doesn't Sound Good
Old Jan 10, 2006 | 02:59 PM
R33P3R007's Avatar
360 L337 User
Doesn't Sound Good
Recently when pulling away from a stop, even really slowly I am getting a bumping noise. It is repetative like bump, bump,bump, bump, then once i am moving it stops and doesn't happen again at all during regular driving. Only once in a while also not everytime I start off.
Any Ideas? sounds like it may be something that is rotating since it happens repeatedly, but wouldn't it get faster with each gear, not stop once I get moving?
HELP
Old Jan 10, 2006 | 03:25 PM
cvenom2122's Avatar
Thumbs up
could be a CV joint
Old Jan 10, 2006 | 03:49 PM
R33P3R007's Avatar
360 L337 User
thanks, any idea how I can check it? to find out?
anyone else break one or mess up an axle? sumthing
anyone..
Help...
Old Jan 10, 2006 | 03:51 PM
Brian MP5T's Avatar
Turn the wheel all the way to one side and drive around, then try the other direction in FWD and REV
WJT DEMON's Avatar
anyone..
Help...
Jack up the front end and inspect the joints. Leave in gear and give both wheels a crank and see if you hear or feel a broken joint. Also look for a ripped boot.
Old Jan 10, 2006 | 03:55 PM
R33P3R007's Avatar
360 L337 User
Thanks... anyone else have a problem like this?
Old Jan 10, 2006 | 03:57 PM
WJT DEMON's Avatar
On different cars yea. Just quit accelerating so damn hard with your wheels turned. lol
Or gravel to pavement spinning can cause failure as well.
Old Jan 10, 2006 | 03:58 PM
R33P3R007's Avatar
360 L337 User
it only happens when i start slowly.. if I launch i hear no noise?
Old Jan 10, 2006 | 04:01 PM
WJT DEMON's Avatar
yea but thats what might have caused the CV failure in the first place. More times than not anyways.
hmm your wheel isn't loose is it?
Old Jan 10, 2006 | 04:06 PM
R33P3R007's Avatar
360 L337 User
never had them off. I'll check that ASAP
Sarbae's Avatar
Jack up and try tilting each of your wheels (side to side, up and down). If your wheels tilt greatly (or even at all in the up-down direction), you've got joint problems. If you don't see anything wrong, turn the steering wheel all the way and try and turn your wheels with your hand while inspecting the boots and you may find some problems.
Good luck.
Old Jan 10, 2006 | 04:08 PM
R33P3R007's Avatar
360 L337 User
Thanks, I hope this is it and I can Fix the problem.
Warrenty?
Old Jan 10, 2006 | 04:09 PM
WJT DEMON's Avatar
Good luck.
Actually the halfshafts are independant of the hub so nothing will tilt. Unless you are talking about ball joints, then yes.
Old Jan 10, 2006 | 04:10 PM
WJT DEMON's Avatar
yes warranty.
Old Jan 10, 2006 | 04:11 PM
R33P3R007's Avatar
360 L337 User
so I should take it to the dealer anyway and be like.....FIX IT!!!!
Old Jan 10, 2006 | 04:12 PM
Sarbae's Avatar
You're right... I've been driving a 1992 blazer around for a while and that's had ball joint and cv boot problems so that was an instinctual reply. By the way, DON'T drive around to check for problems; that's quite possibly the dumbest thing you can do.
WJT DEMON's Avatar
yea thats what I would do.
Old Jan 10, 2006 | 04:37 PM
selfinfliction's Avatar
one dude a couple months ago snapped an axle driving up a hill, but that's the only broken one i think anyone has seen
Old Jan 10, 2006 | 05:15 PM
WJT DEMON's Avatar
I wouldn't necessarily call broken axles, CV joints, or any suspensions related parts a problematic area of any single type of vehicle. Most of those failures are human error related.
alleycat58's Avatar
I've got a suspension problem now too, not sure if it's the CV boot or if it's the right front shock. Something blew and there's grease EVERYfreakinWHERE inside the wheel well. Thank god I have 4 days off for it to sit at the shop.
Old Jan 10, 2006 | 05:16 PM
WJT DEMON's Avatar
CV boot.
Old Jan 10, 2006 | 05:32 PM
alleycat58's Avatar
CV boot.
That was my thinking too, hopefully they'll fix it with no problems, I've never done anything to the car that would cause the CV boot to crack.
Old Jan 10, 2006 | 06:22 PM
redlineblueline's Avatar
I had the right drive axle "holder" break and it disconnected from everything and it started out as a slight rough driving almost as if the tire was flat it would bump at slow speeds.
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
