F23 Quaife LSD install
Old Apr 5, 2018 | 07:27 PM
  #151
jdbaugh1's Avatar
https://zzperformance.com/ecotec/adj...or-cobalt.html
Anyone think this would be worth giving a try? It's not obvious to me that this is a more common issue than I was aware of. According to their description this sounds like it may give me just enough to prevent high rpm drag.
Old Apr 5, 2018 | 07:34 PM
  #152
Originally Posted by jdbaugh1
Does anyone know if Sachs is OEM or if Luk a good brand for master cylinder?
Those are both name brands I would trust.
Old Apr 5, 2018 | 07:35 PM
  #153
Worth a shot IMO.
Old Apr 5, 2018 | 07:37 PM
  #154
jdbaugh1's Avatar
Worth a shot IMO.
I think so too. They can be installed by only having to remove the fuse box correct? Not a bad piece to have even if it doesn't correct my issue.
Old Apr 5, 2018 | 07:49 PM
  #155
I believe thats all you have to do.
Old Apr 5, 2018 | 08:03 PM
  #156
Henry3959's Avatar
If I was running a performance clutch setup I would want adjustability. Nice option....
Old Apr 15, 2018 | 02:06 PM
  #157
jdbaugh1's Avatar
Well the adjustable master cylinder seems to have done the trick. However now I noticed that my boost will drop off with higher rpms especially in second gear. I shift into third and sometimes it will boost fully and keep on boosting then other times it will boost up and then drop 5 psi or so suddenly and stay down there. I am thinking I am getting belt slip as I don't know what else could cause boost issues intermittently and the way the boost drops it looks like it is fine until it starts to slip and then it continues to slip. I disconnected my boost bypass solenoid and that is not what is doing it. Right now I have the ZZP adjustable tensioner on it's least tight setting combined with stock LSJ belt, phenolic spacer, supercharger 1/2" spacer, a 2.9" pulley and an ATI overdrive. Going to try and go one setting up on the adjustable tensioner. It seemed too tight when i first installed it to go up at all but maybe the belt has broken in a bit or maybe I was just being a puss.
Old Apr 15, 2018 | 06:59 PM
  #158
cluelessk's Avatar
Could be slip. Everything is sealed? No leaks from the supercharger to intake manifold?
Old Apr 15, 2018 | 07:28 PM
  #159
jdbaugh1's Avatar
I double checked with some carb spray and couldn't get a reaction anywhere. The problem is definitely more rpm related than it is pressure related. Like I was saying high load lower rpm produces good boost/power
Old Apr 15, 2018 | 09:44 PM
  #160
Make sure it isn't your bypass dropping boost
Old Apr 15, 2018 | 10:03 PM
  #161
jdbaugh1's Avatar
I disconnected the solenoid completely, plugged off the solenoid side and left the actuator side open to atmosphere. Actuator is closed in its at rest state. Only thing that can open it is vacuum signal from partially closed throttle body or something restricting the intake.
jdbaugh1
Jul 23, 2018 02:39 PM
574
Dec 12, 2014 12:39 AM
DeLorean
Oct 17, 2011 06:50 PM
zinner
Sep 25, 2005 06:13 PM
RA071623
Aug 22, 2005 05:11 PM
