f23 tranny rebuild/ ss/sc tranny swap
Old 07-12-2007, 10:07 PM
mike25's Avatar
so as the title says....what woulod be easier and more efficient .....an f23 rebuild to handle more power or an ss/sc tranny swap...with the ss/sc tranny swap would it really need tuning to run the new trans....i would just thinkt hat i would need all the proper cables and stuff like that....what all would i need to perform this?
Old 07-13-2007, 11:05 AM
mike25's Avatar
cmon someones gotta know something?
Old 07-13-2007, 02:47 PM
ridemlow03's Avatar
isnt the f23 a SS/SC transmission?? i know the ss/sc open diff and limited slip transmissions are going to be equal in strength. only difference is the diff. if i were you get all the gears cyroed treated, not sure exactly how to spell it. do that and get it beefed up more, a performance transmission place should know tricks on how to build your tranny up. thats who you really need to talk to.
Old 07-13-2007, 07:26 PM
Brandon97Z's Avatar
hahn has run 11's in their turbo sunfire on a F23 trans with mearly a clutch upgrade. The trans itself can handle it.
ss/sc trans=F35
Old 07-13-2007, 09:02 PM
ridemlow03's Avatar
ss/sc trans=F35
sorry about that still new to the cobalts, only had for a couple months. still dont know everything about the balts but im getting there. which are stronger the f23 or f35??? may be a dumb question but sometimes, older transmissions can be stronger than new ones.
Old 07-13-2007, 09:08 PM
mike25's Avatar
i know the tranny can handle it...but my tranny was alearner....and its got a decent amount of damage done to it.....when the time comes im either going to buy an f35 and drop it in or rebuild the f23 tranny
Old 07-13-2007, 09:46 PM
BanyasRacing's Avatar
these trannies have weak rear ends if you get a better differential the tranny should hold up to alot of abuse.i installed the quaife diff on my ss and its great. im really hard on my car and am suprised in the beating my tranny has takn .
Old 07-13-2007, 09:47 PM
Brandon97Z's Avatar
Well i believe the bellhousings are different so you'd have to have someone make an adapter plate if you really wanted to use the f35 but then you gotta think about space issues. Honestly if you want replace the stock on, either have it re-built, buy a brand new f23, or find a used one with low miles on it. Just get a stronger clutch and maybe even a lightweight flywheel if you want.
05-28-2022 03:47 AM
ThoR294
10-04-2015 08:44 PM
OrangeCoba
10-01-2015 10:00 PM
Iceberg
09-29-2015 12:33 PM
Iceberg
09-28-2015 01:31 PM
Quick Reply: f23 tranny rebuild/ ss/sc tranny swap
