F40 swap
Old Apr 23, 2008 | 11:01 PM
Tinkles's Avatar
F40 swap
Who here has swapped a Saab F40 into their balt'?
Old Apr 24, 2008 | 05:47 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
No one. I thought about it... but never did.
Old Apr 24, 2008 | 09:05 PM
Tinkles's Avatar
There is a guy on Saabforums swearing that he drove his buddies F40 6-speed Cobalt SS. hmmmm
Ok thanks.
GULLABLE0NE's Avatar
sounds like big money put in on that job
Old Apr 25, 2008 | 01:23 AM
Sharkey's Avatar
i have done a lot of research on it and come up with some answers and a whole lot more what ifs
-i know the spline count on the f35 axle is the same as the f40, so the drivers side axle will pop right in. what i dont know is if the diff centerline is exactly the same between them, this comes into play with the seatdy shaft and bearing as if its not in the right spot itll take out diff carrier bearings and steady bearings. if they are not the same, a steady bearing from a saab may need ot be used, or mabey the whole shaft.
-the saab turbo comes with an 8 bolt crank, so the f40 flywheel and clutch should bolt right up. what i dont know is if the f40 clutch and flywheel is the same as the f35.
-mounts would all be custom
-shifter anbd cables iant really hard to figure out, just be creative..
Old Apr 25, 2008 | 01:27 AM
The shifter can be taken out of a Saab... it looks exactly the same as the stock SS/SC... only with 6 gears.
Old Apr 25, 2008 | 01:28 AM
da_kage's Avatar
sharkey are you drunk?
Old Nov 1, 2011 | 09:17 PM
rmay635703's Avatar
I thought the pontiac G6 came with an F40 and therefore should drop in being nearly identical?
Old Nov 1, 2011 | 10:04 PM
Sharkey's Avatar
the g6 did come with an f40, however its the wrong bellhousing bolt pattern. the g6 with the f40 was only a 3.9l v6, so it used the small gm bolt pattern, not the ecotec pattern. im sure you could use the same adapter that is used for the 4t65e race tranny, however it would be a lot easier to use the saab 9-3 version of the f40 that is mated to an ecotec.
Old Nov 1, 2011 | 10:25 PM
FryLoch's Avatar
I was interested in doing this years ago but after the research I found it's not really worth it or going to be a direct swap.
Old Nov 1, 2011 | 10:29 PM
alexx's Avatar
F40 trans for sale if anyone is interested in attempting this
Old Nov 1, 2011 | 10:36 PM
Dart_SI's Avatar
Someone try it. Better gearing would sound awesome.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
ThoR294
Sep 28, 2015 05:31 PM
ashalle2
Sep 27, 2015 03:28 PM
