How bad is stalling?
Old Nov 9, 2005 | 03:34 PM
silverSS's Avatar
so....what exactly does it do to your car, just curious....it's obviously not good, but can someone give me some details......
just wondering a little, b.c today when i went to get that screw out of my tire, the guy stalled my car when backing it out of the spot to pull it in the garage i just kinda laughed cuz he was at least 35, but ive heard our cars are hard to drive, for someone not familar
Old Nov 9, 2005 | 03:37 PM
VaMP's Avatar
I don't really consider it all that bad of a thing... it happens...
And the Cobat SS S/C has one of the best shifting transmissions I've ever experienced. Don't listen to those people, Car and Driver says we have a heavy clutch, what a bunch of babies.
Old Nov 9, 2005 | 03:55 PM
c7015's Avatar
they said it about the countach too ...though the shifter is not the most precise I have experienced but nothing to gripe about
Old Nov 9, 2005 | 03:56 PM
b-spot's Avatar
I thought we had a fairly light clutch until I drove my friends TSX. Driving my car felt like a workout after, heavy clutch, long throws. The TSX transmission was AMAZING.
Old Nov 9, 2005 | 04:01 PM
Alex47's Avatar
HE STALLED UR CAR!!!!!
NOW YOUR TIMING US FUCKED.
NOW YOU NEED A NEW CAR
lol nothing bad happens when stalling
Old Nov 9, 2005 | 04:34 PM
silverSS's Avatar
lol
Old Nov 9, 2005 | 04:46 PM
Sarbae's Avatar
Unless of course it stalls due to a lack of fuel or something, then you're in for a bit of work replacing filter and cleaning out the injectors, and you're a woman
Old Nov 9, 2005 | 04:49 PM
R33P3R007's Avatar
360 L337 User
it normally takes a few seconds to start back up after a stall, other then that not much
Old Nov 9, 2005 | 05:16 PM
jerm's Avatar
On a car with manual transmission, it'll happen from time to time.
Especially with someone that isn't familiar with the clutch in our cars (or any car for that matter).
Old Nov 9, 2005 | 06:39 PM
badg1rl's Avatar
one stall wont hurt. i used to stall quite frequently when i was first learning. im still kinda new to stick...every1 laughed when i bought a car i couldnt even drive. LOL
Old Nov 9, 2005 | 07:03 PM
Cirrus's Avatar
you forgot that its GUNNA EXPLODEZ0RZ!!!
Old Nov 9, 2005 | 07:05 PM
xskier874's Avatar
every one stalls when they learn how to drive stick its just a matter of getting used to it if stalling messed up your car i think i woulda had to bring my truck to the shop 314069187424198 times cause my sister, I , and 2 of my friends learned to drive stick in it...
Old Nov 9, 2005 | 07:24 PM
T Dawg's Avatar
When I got mine I had tested a honda yuck and a carolla, all of which were stick. I hadn't driven a stick for about two years, i stalled the honda, did well with the toyota, the smoked the hell out of the base cobalt tires. Much better for my driving style, so I bought it. :-) Had to go base though, worse yet, sedan. The wife was there. Something about price and getting the kids in and out of car seats.
Old Nov 9, 2005 | 07:48 PM
Cobalt_Supercharged's Avatar
Our clutch is heavier than my sisters 95 Eclipse GS. After I had my car for a couple of months I drove hers again and couldn't tell it my foot was on the pedal or not. I just put my foot down where I thought it was and started the car. Then I thought "did I push in the clutch?". I had, but I didn't feel it because I was so used to how heavy mine was.
Old Nov 9, 2005 | 07:54 PM
wesmanw02's Avatar
As the other guys said, stalling itsn't really a big deal. Instead of cutting fuel and spark to shut the engine off, you're just forcing it to stop with the resistance from the weight of the car
As far as clutches go, I'd say the SS S/C's clutch is spot on in terms of feel and resistance. I personally can't stand clutches that are super light or have no feel (like our Civic), it makes it much less engaging performance wise and more difficult to drive smoothly. However, Honda is known for having great shifter assemblys, I won't deny that at all; they have some of the most accurate and smoothest in the industry. The best clutch I've experienced is probably the one in the C6 Corvette, its about as perfect as they get. Just the right amount of resistance, and the engagement point is right where it should be in the clutch travel - you can feel the engagement point even with the engine off.
I think the worst clutches are those found in some high-horsepower muscle/sports cars, like the 03-04 Mustang Cobras. They have some of the stiffest clutches around, its like driving a dump truck
dimeo09's Avatar
ive driven about 8 manual cars and i dont see a huge different in the feel, ours is def heavier though
Old Nov 9, 2005 | 08:02 PM
alleycat58's Avatar
Same here!!!! The only time I stall it now is occasionally when I'm starting on a hill and someone is a little too close for comfort behind me sometimes I'll think about it too much and stall it (I'm too proud to use the e-brake trick unless I know I can't get started without drifting into the person behind me.
Old Nov 9, 2005 | 11:09 PM
VaMP's Avatar
I've noticed that in the SS S/C when starting it, you can just barely engauge the ignition and back off and it'll start. But after you stall, it takes like 5 seconds of cranking. Now when you're used to just turning the key for a split second, and it starts, you look like a fool at an intersection after it dies and you're trying to do the split second starting, lol.
alleycat, when someone is that close to you, rev to about 2000 and drop it.
Old Nov 9, 2005 | 11:57 PM
I would have said 3000, but to each their own
Old Nov 10, 2005 | 12:03 AM
ExHondaMan's Avatar
Domestics Pwn
Stalling your car doesnt do anything bad. All thats happening is the motor isnt producing enough power to turn the wheels.... Youll notice if you dont hit the gas and let out of the clutch slowly the engine rpms will drop... If you let out the clutch too fast without enough gas (increased rpm) the rpms drop too low and the engine stalls (engine cant run at 150rpm). I stall my SS all the time. Ask the AZ SS/SC guys
Yay I win most stalled SS by an experienced driver
Old Nov 10, 2005 | 12:12 AM
I'll vouch for that. The tape might back it up as well.
turbochargedss2012
Sep 20, 2023 12:17 PM
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
Iceberg
Sep 29, 2015 12:33 PM
Trav3480
Sep 28, 2015 02:46 PM
