How to lsd swap?
How to lsd swap?
Does anyone know or have any instructions of a limited slip differential that can be swapped into a trans without it? This is for the F35. Thanks!
Also anyway of being able to tell if a trans has it or not by looking at the barcode of the transmission itself? It came off a 2007 lsj, but i dont know the vin of the car and i dont know where else i can look it up. Thanks guys!
Its very easy. Look in the hole where the axle goes . If you can see a shaft its non LSD. If you cant see through the axle hole and see the shaft its LSD. Heres a picture of the shaft in the non LSD
Thanks guys and mongoRat for the pics! Def helped!
Is it a hard process to swap the LSD at all? Any specific things needing to be bought?
Last edited by ryansalazan; Aug 29, 2012 at 01:02 AM. Reason: Automerged Doublepost
ThoR294
Oct 4, 2015 08:44 PM
importkiller
Sep 30, 2015 07:18 PM
