LNF Trans help
Old Apr 13, 2019 | 08:50 AM
Geo_SS's Avatar
LNF Trans help
Hey guys, so this happened to me while heading to work, I was in first gear getting on to the freeway when my gear just popped out. I pulled over to the side and i couldnt put my car into gear, any gears. So i turned off the car and that was the only way the gears go in when the car was off. Any help guys? Its my daily and i have about 172k on it. I have stage 4 southbend/findaza flywheel, new clutch master cylinder, TOB. All these parts were installed about 7 months ago. So everything is brand new.
Old Apr 13, 2019 | 01:12 PM
Sounds like a clutch release issue. Is it leaking brake fluid underneath?
Old Apr 13, 2019 | 07:56 PM
Geo_SS's Avatar
No leaks, the pedal is fine just feels a bit stiffer.
Old Apr 13, 2019 | 10:47 PM
63 Nova SS's Avatar
Cables stretched? Or did you break a roll pin? Does it grind? I agree it could be an issue with engagement. Anyway the clutch or flywheel could have worn enough to not allow enough stroke for the tob?
Old Apr 14, 2019 | 12:02 PM
Geo_SS's Avatar
Im going to check the cables today to see if i find anything, but no it doesnt grind. When the car is off it goes into gear. When its on i cant put it into gear even holding down the clutch pedal.
Geo_SS's Avatar
Not to mention I bought all that stuff about 8 months ago
Old Apr 22, 2019 | 09:09 PM
C0balts5's Avatar
Did you ever figure it out? Sounds like something let loose in the clutch and is dragging
Old Apr 24, 2019 | 09:53 PM
Geo_SS's Avatar
This is whatp my clutch looked like after 8 months.. I just use my car as a daily. To work and school thats it.. Have never ran it since it was put on.
Old Apr 24, 2019 | 10:01 PM
C0balts5's Avatar
That should be warranty. 12 month 12k miles
Old Apr 24, 2019 | 10:08 PM
Geo_SS's Avatar
Yeah I talked to someone at southbend and they want to see pictures of it. So hopefully they warranty it because im not going to paid another 1,400 total just to replace this.
Old Apr 25, 2019 | 06:35 AM
C0balts5's Avatar
Im right there with you, I bought the exact same clutch 7 months ago after blowing apart 1 factory clutch, and 2 clutchmasters fx100. Bought the south bend one and used a factory flywheel. Saw so many good reviews on it and figured it would hold together better than the last 3 clutches but this makes me a lil worried. I don't launch or beat my car to death either, I am however full bolt ons and pushing 23 psi so that may have helped kill mine.
Old Apr 25, 2019 | 06:51 AM
C0balts5's Avatar
Old Apr 25, 2019 | 01:58 PM
Geo_SS's Avatar
Crazy thing is Im bolt-ons only no tune and this still happened.. damn thats a lot of clutch jobs you went through. Thats the reason why i got mine too is because the good ratings.
Old Apr 25, 2019 | 02:04 PM
C0balts5's Avatar
I hope and pray to the car gods to cut me a break. Im thankful it's not my daily, took 7 months just to get 1200 miles on it
Old Apr 25, 2019 | 03:27 PM
Geo_SS's Avatar
Yeah hopefully everything works out for you, it sucks going through this. So I was emailing back and fourth a representative named Dj and he was very helpful. I sent him pics and he basically took a look at the clutch and said the clutch might have been bent before or after the installation. Meaning put on wrong and that it was at an angle while operating, that is what he told me. All in all he sent me a need disc only not the pressure plate. That he said was still okay to use. Well see how this holds up.
Old Apr 26, 2019 | 06:39 AM
C0balts5's Avatar
As long as there is no blue spots, more than likely you will be ok, if there is blue hazing anywhere than your going to get clutch chatter because it's warped.
littlered
Dec 8, 2015 07:30 PM
2010SSTC
Sep 19, 2013 07:33 AM
PsychoCam
Jul 26, 2013 08:25 PM
buter
May 25, 2013 01:54 PM
SS FREAK
Dec 6, 2010 05:01 PM
