People that are running spec clutches please step in
Old Feb 4, 2011 | 10:34 AM
FF_ace's Avatar
so a lil over a month ago i did my engine build while i had the motor out i installed the spec 3+ with lighter flywheel. my question i have to people that have the same setup is on cold start ups do you have rattling noises at idle that comes from there? its goes away once i give it a lil gas or drive around for a lil bit and everything is all warmed up. Also after the cold start up when i start to go and i engage the clutch it screeches a lil but that goes away after everything is warmed up as well? is this normal?
Old Feb 4, 2011 | 03:12 PM
Iam Broke's Avatar
Spec S2+ here w/ LWFW, the crying & moaning is normal cold, no rattles though. Sure it's the clutch? Only when the pedal is down or when released in neutral?
Maybe a loose spring on the disc plate?
Old Feb 4, 2011 | 03:24 PM
FF_ace's Avatar
Well it only rattles on cold start up when its warmed up it doesn't rattle anymore
And its when the pedal is released and in neutral
Old Feb 4, 2011 | 03:27 PM
kxrida2000's Avatar
does it go away when u press the clutch pedal in
Old Feb 4, 2011 | 03:28 PM
StevesBlack06's Avatar
Stupid question BUT... Did you make sure to use your alignment tool? Spec clutches = garbage. End discussion.
Old Feb 4, 2011 | 03:54 PM
FF_ace's Avatar
goes away when I press the clutch in.
yes I used the tool
Old Feb 4, 2011 | 04:03 PM
BlackBeast!'s Avatar
Its all normal nick my ss/sc car did the exact same thing just a little clutch chatter thats all
Old Feb 4, 2011 | 09:17 PM
Zero6LS's Avatar
Ive got a stage clutch and dont have any problems with mine. Its been in the single digits here temp wise and my cars doing ok still
Old Feb 4, 2011 | 09:21 PM
elecblue06's Avatar
mine does the same thing but only when it's cold.. something i noticed that was a "rattling" was actually my windshield washer top moving because of the extra vibrations lol
but once the car warms up i dont notice it anymore
Old Feb 4, 2011 | 09:24 PM
doober321's Avatar
Mine does it to I'm sc. I was told that it's indeed clutch chatter
Barkleyj605
Oct 24, 2015 12:07 AM
Hugger1975
Oct 15, 2015 03:28 PM
How to Guide
57
Oct 15, 2015 11:56 AM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
