replacement clutch opinion
Old 10-26-2011, 06:32 PM
Refractor's Avatar
Question replacement clutch opinion
I did some searching, but I'm looking for opinions and experience with this one.
The stock clutch in my 07 SS is going, its slips in 3rd, 4th, and 5th. I'm looking to get the gmpp clutch upgrade kit (approx $230) and have the original flywheel resurfaced. I've got an estimate for $500 labor if I supply my own parts. The car is essentially stock though eventually I'd like to get about 275hp out of it.
My question is this:
From experience, are there better clutches to be had for a similar price, or will the gmpp clutch be perfectly adequate? Are there better clutches that can use the same flywheel? Money is TIGHT right now.
Thanks.
Old 10-26-2011, 06:55 PM
Gelladuga69's Avatar
Thanks.
If money is tight, I'd suggest staying with the GMPP upgraded kit. It's basically the cheapest quality kit you can buy, without a flywheel.
It's cheap and handles up to 300hp, I think?
Old 10-26-2011, 07:42 PM
Vander Nars's Avatar
everyone says gmpp and its rated 300 hp but iv read it can hand alot more then that.
Old 10-26-2011, 08:44 PM
Refractor's Avatar
Awesome, thanks for the input!
Old 10-26-2011, 09:09 PM
Dart_SI's Avatar
gmpp clutch is basically an LNF clutch, which is good for 350tq. i doubt you will be pushing 350tq, even on a TVS n shyt. your good.
Old 10-26-2011, 09:17 PM
vroomvroom's Avatar
that's the exact setup i have and it's great. smooth, easy to drive, and never slips (although i'm nowhere near 300). includes the lnf tob also if i'm not mistaken which is a good deal.
Old 11-02-2011, 06:46 PM
Refractor's Avatar
The clutch arrived today! I'm surprised as how lightweight and almost fragile it feels.
Old 11-03-2011, 01:08 PM
stonny9's Avatar
gmpp clutch is nice when driven properly. blazzin has a gmpp and over 400whp turbo setup with no slip and before that was on a nitrous setup. Is that the price joe gave you? He does work on most of the known balt owners down here and has done several motor swaps. Job is really tedious. You have to drop the subframe. And dont even try and put the trans back in by yourself unless you have a proper jack setup and have alot of patience or you are strong and have put a few in already.
Old 11-03-2011, 01:15 PM
BYT*SS*TURBO's Avatar
I believe Area made the 400hp on the GMPP clutch IIRC. Good choice for what you have IMO.
Zharrington_2010LNF
02-08-2016 01:43 PM
justinchinn
10-02-2015 12:18 PM
Trav3480
10-01-2015 08:17 PM
SSLOW06
10-01-2015 07:21 PM
Tupp
09-30-2015 08:18 PM
Quick Reply: replacement clutch opinion
