rotated mounts
Old Mar 6, 2011 | 06:32 PM
nfarrall's Avatar
rotated mounts
I just installed ottp rotated stage 2 mounts and im still getiing wheel hop. i tried the loosening the engine mounts for everything to settle and leaving the bolts slightly loose so everything can settle even more and its still hopping like a ****.
Old Mar 6, 2011 | 07:30 PM
slowstang's Avatar
I did the TTR STOP mounts and still had wheel hop even though it was 10x better than the stock mounts. I then purchased the TTR engine mount and it stopped wheel hop on the street but I still have a tiny bit at the dragstrip.
Your next step is to either get an engine mount or ingalls TD.
Old Mar 6, 2011 | 08:04 PM
northvibe's Avatar
Did you tighten them to the right torq spec? ALSO big tip from when I installed mine. Loosen the 3 bolts on the passenger side engine mount. Let the motor move by itself, then tighten all 3 down again.
Old Mar 6, 2011 | 08:42 PM
nfarrall's Avatar
i loosened the three engine mount bolts for the install and yes i torqued them down correctly its still just as bad as the stock ones
Old Mar 6, 2011 | 08:49 PM
northvibe's Avatar
what mods do you have? how much power are you making. what axles do you have? what tires? whats the temperature?
Old Mar 6, 2011 | 08:51 PM
HB_SS/TC's Avatar
tire pressure is probably too high too
Old Mar 6, 2011 | 08:53 PM
nfarrall's Avatar
stage 2 cai 2.9 pulley longtube headers catback stage 1 axles and spec stage 3 clutch and i have the stock 18s wrapped in goodyear eagle f1's
Old Mar 6, 2011 | 09:11 PM
nfarrall's Avatar
Old Mar 21, 2011 | 08:16 PM
NexTnmE's Avatar
ut oh I'm about to install the Stg1 kit... hope I dont have this problem...
Sl0wbaltSS
Nov 21, 2018 11:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
importkiller
Sep 30, 2015 07:18 PM
nathan112i
Sep 30, 2015 07:12 PM
