Snapping noise
Old Aug 21, 2008 | 04:10 PM
Pantera's Avatar
Snapping noise
2006 cobalt ss supercharged..
the story goes if i dont rev match when downshifting, when it ingauges after it revs a loud snap with bellow from my car.. ive been able to re-create the noise otherwise with driving around 3-4 rpm then not fully depressing the clutch and releasing it again, after doing that ill hear about 4 quick snaps one after the other.. ive tried looking up this problem but the shop i work in is insanely busy so i dont have time to diagnose my own car.. UGH.. if anyone can help please do so
Old Aug 25, 2008 | 02:32 PM
Pantera's Avatar
ive heard of a possible engine mount problem?? anybooody....
Old Aug 25, 2008 | 02:34 PM
Dead Zen's Avatar
check your tranny for cracks or a loose mount
Old Aug 25, 2008 | 02:37 PM
ls1fbody's Avatar
Haz l33t wheelz.
check all your mounts, also, check your cv joints, although that would be more of a crunching/grinding.
Old Aug 25, 2008 | 02:47 PM
Dead Zen's Avatar
i had a noise like your describing
Old Aug 25, 2008 | 02:51 PM
ls1fbody's Avatar
Haz l33t wheelz.
damn, mine didn't make a noise at all, just felt like the clutch went out, and then there was brake fluid everywhere!
Old Aug 25, 2008 | 02:52 PM
Dead Zen's Avatar
i could hear movement when i gave it a little gas or on decel.
Old Aug 26, 2008 | 02:59 PM
Pantera's Avatar
holy **** i hope thats not what it is, and its just mounts..
Old Aug 28, 2008 | 01:08 AM
joe118969's Avatar
Its a chavy, trannies on these cars are the biggest pos around. I think mines cracked or my main seal is going, got oil between the tranny and engine, and on the oil pan.
Old Sep 16, 2008 | 12:18 PM
Pantera's Avatar
ive now checked my engine mounts and they seem to be fine.. now ive been thinking if its some loose bolts in the subframe or anywhere in the engine compartment, this noise is a horrid sound and im just dying to get rid of it...
Old Sep 17, 2008 | 03:48 AM
SprChrg4Life's Avatar
if it has anything to do with the engine/tranny movement, try sitting still in neutral and have a friend or some1 quickly give the engine a quick 1/2 pedal down and release while parked, rev the sucker up and torque it up, moving the engine as much as u can while not moving... see if u can emulate it while you're outside the car. and tighten the bolts for your mounts and such too, yes.
dead zen, in those pics you have stock mounts... how did you crack the tranny where the front mount goes with stock mounts?? im kind of scared now!
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
