Terry11's 4t45/4t65 Auto Swap
Old Jan 29, 2013 | 07:22 PM
terry11's Avatar
Thanks bud wish it would have worked out on your ride. We'll find out sooner or later! I'll just be enjoying the car for a few months after the build is "done" before I try and test the waters some. I'm thinking middle of next month for the initial startup.
Got the trans linkage and shifter all bolted on and hooked up tonight. Still need to finish wiring the powertrain control solutions module and button up the charge pipes, gauges, and oil cooler hoses then we'll be in business.
Old Jan 30, 2013 | 07:56 AM
Tundraboarder666's Avatar
Hmmm im really confused as to how this is going to work... never heard of anything like it before. It looks like a regular 4t45e just with the upgraded axle? Or are clutches for the 65 too? The thing that fails so hard with the 45 is that its so small and overheats so quickly. Also the clutches being so small too. I wouldnt think that the 65 clutches would fit in the 45... ive blown 4 45s 1 stock and 3 built. Looking like the 65 is the only option out there for me... but dont want to spend 15000 dollars on a trans either. When my cars only worth 6... lol
Old Jan 30, 2013 | 12:37 PM
terry11's Avatar
haha i hear ya man. The 65 is what i'll end up with in the long run: custom converter, bell housing adaptor, mounts and the build trans. The pcs unit i'm using and I believe the harness as well will work with the 4t65.
The reason it looks a little funny is because it's the only one in existence. It was ran on 15psi from a 57mm with no issues at all. Right now i'm just looking forward to cruising around and familiarizing myself with the tuning software. When it does come time to track it i'm just looking for baseline numbers and hopefully I can gather a lot of good info on how my car will react coming off the line and learn how to set it up.
The car should stay cool I have full control of the fans through the pcs unit
Old Jan 31, 2013 | 03:53 PM
terry11's Avatar
Laaadeedaaaa
Old Jan 31, 2013 | 04:15 PM
EXsoccer1921's Avatar
nice dryer ducting! hahah.
Old Feb 4, 2013 | 01:38 AM
terry11's Avatar
yeaaahhhhhhh niccaaa! haha
Might fire her up this Saturday possibly sooner depending on work
Oh and that dryer hose is getting heat wrapped and painted
Old Feb 4, 2013 | 01:50 AM
how solid is it? flimsy where it will collapse when the turbo is pulling in a lot of air? and do you have a piece of metal clamped to the filter and then the ducting clamped to that?
Old Feb 5, 2013 | 05:21 PM
terry11's Avatar
I don't know yet thats what I'm wondering myself. If you keep it all pushed together like I have it it's strong I can't crush it with my hands so I doubt it will suck shut at 12-15 psi.
Yeah I have an aluminum piece in there. Thats where the bung is going for the catch can "return line." If I even go that route the hoses might just stay pointed towards the ground forever. Or a big can with a massive breather just for cleanliness' sake.
Old Feb 5, 2013 | 06:19 PM
lol to the ground is where it's at. that's how i have my two lines ran just for the time being until i figure out what i really want to do with it.
Old Feb 6, 2013 | 05:03 PM
terry11's Avatar
I'm so used to the oil vapor smell it would almost be weird to not have it.
I would like to do it the right way. Both my lines to a nice big "can" then a 3/4" line back to the intake. I just don't know where to put it.
I'm probably going to be making an aluminum tank to put beside the coolant tank for extra trans fluid. Then it would be very easy to add more.
Old Feb 6, 2013 | 05:59 PM
  #36
Area47's Avatar
Rent me! per hour
will ya look at that, someone got a hold of a set of 272 grinds
Old Feb 6, 2013 | 07:06 PM
  #37
terry11's Avatar
just look at it
have you used them before? I haven't been able to REALLY test them out yet
Old Feb 7, 2013 | 12:10 PM
  #38
Area47's Avatar
Rent me! per hour
i think i was the second person to use them in the lsj years ago.
Old Feb 7, 2013 | 03:41 PM
  #39
terry11's Avatar
Such a Pioneer! How'd they do?
Ex I got a picture for you then. My dryer vent is perfectly hidden now. if anybody asks me I'm gonna lie my ass off it's aluminum haha
Old Feb 7, 2013 | 04:26 PM
  #40
Area47's Avatar
Rent me! per hour
witt was the first, i think i was the second, and 06black was the third.
did just find, good solid top end, but the lash adjusters never fully adjusted to them. solid lifters, or shims will be needed. there is a dyno graph floating around somewhere of them on my m62 setup
Old Feb 7, 2013 | 06:31 PM
  #41
terry11's Avatar
hmm....really? Mapco machine did me head for me they never said anything about different lifters. It might have already been done because the head was complete when I got it I just had it freshened up and a few other things.
Old Feb 7, 2013 | 08:38 PM
  #42
Silverbullet33's Avatar
probs some of the nicest colours ive seen doen under the hood.... i LOVE it aha
Old Feb 7, 2013 | 09:14 PM
  #43
armcclure's Avatar
Nice to see this thing going together.
One suggestion:
Instead of messing with a pedal switch for the cutout,
Just get a Hobbs switch from NAPA set at like 7-10 psi. Seems easier to me; that's what I plan on doing soon.
Old Feb 8, 2013 | 11:08 AM
  #44
terry11's Avatar
One suggestion:
Hey, thanks Silverbullet. Appreciate it man
Thanks for the idea! I can actually do it with my trans controller and a spare digital output wire. I can command it to open at whatever throttle percentage I want
Old Feb 8, 2013 | 01:00 PM
  #45
armcclure's Avatar
Ahh. Even better lol
Old Feb 9, 2013 | 04:13 AM
  #46
terry11's Avatar
Big problems on start up tonight.
1.) I keep getting cam sensor timing codes and I checked it 3 times. I know how to properly time the engine and the sensor. I've ran my car with the cam sensor out of time before it just takes a while to start so i know thats not why it's going into "EPR" and/or Engine Disabled.
2.) My throttle body is going crazy like fluttering violently when I crank the motor. As soon as I do it kicks into EPR and slams the tb shut when the engine fires and kills the motor. I'm getting tps codes and p1516 almost seems like my tb took a ****.
And when it throws EPR and Engine Disabled I get a bunch of pcm codes.
I don't know why a throttle body would cause all that maybe I have something else going on, but I'm going to start from there. What makes me think its the tb is when I clear the codes and turn the key back on the tb responds to the pedal movement perfectly, but as soon as I turn it over it kicks like 5 codes goes into Engine Power Reduced and closes the tb instantly. The car won't even stay running for 3 seconds.
My best guess on the cam sensor timing is it needs a case relearn, but I need it to run in order to do that. Yayyyyyyy love it
Old Feb 9, 2013 | 01:39 PM
  #47
armcclure's Avatar
Make sure the pins are all straight on the plug...
I chased myself in circles for a week hunting down a cpa code only to find that.
Old Feb 11, 2013 | 11:59 AM
  #48
terry11's Avatar
Ok i'll check that. It's weird because I didn't change anything electrical wise. Just added a few things. My car still thinks it's "stock"
Old Feb 13, 2013 | 05:15 PM
  #49
Found a guy locally who said he would be able to do the 65 internals in a 45. depending on how yors holds upthat may be the route i end up going.
Old Feb 13, 2013 | 07:54 PM
  #50
terry11's Avatar
Wow dude are you serious? You mean built 65 internals or just stock ones?
