weak clutch
Old Oct 31, 2009 | 03:02 PM
Schaeffer's Avatar
there is nothing wrong with 42s and a 2.7... ive seen pulse widths as low as 17ms on that setup where the injectors are nowhere near maxed... and then ive seen them as high as 22ms which is terrible.
Old Oct 31, 2009 | 03:32 PM
miked5426's Avatar
it just create a F load of heat. im gonna put my 2.8 back on..after i get a H/E and a dual pass
Old Oct 31, 2009 | 03:39 PM
Schaeffer's Avatar
yeah it does create alot of heat.. but look at my car for instance.. im running a 2.7 on it with the ottp h/e and 80/20 mix of meth. my iat2s after a 2nd thru 3rd gear pull dont ever get above 130. and when im cruising it is typically around 15 to 25 degrees above ambient temps..
Old Oct 31, 2009 | 03:56 PM
miked5426's Avatar
swet. hey i just replaced my ic pump after i saw 185+ iat2 temps.
crusing my iat2 temps were +30 over ambient.
is there a way to tell if the pump is working?? and if it wasnt, shouldnt my cruising temps been higher than that?
Old Nov 1, 2009 | 08:05 AM
Karlen89's Avatar
I guess my clutch isn't as bad as I thought it was. It never slips, but I was getting worried about it because it's at 89k on the stocker.
Old Nov 1, 2009 | 10:24 AM
miked5426's Avatar
dont worry. i got 136k... on my stocker. if you drive it fairly normal...itll last 200k
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
