Why do I still have wheelhop?
Old May 14, 2006 | 04:18 PM
Ern's Avatar
Ern
Ok heres the deal. I just installed my ingalls TB and its set at around 11 or so mm. I have the RSM Tranny Mount and my tires have 32 psi in them right now. I have 225/45/18s on a 7.5 inch rim. I still get wheel hop if i let the clutch out slowly at aroudn 2k then mash it to the floor.
Any ideas?
Old May 14, 2006 | 04:31 PM
Shortbus's Avatar
It could have come loose, or the install was wrong, or bad, try tightening it up.
Old May 14, 2006 | 06:41 PM
Ern's Avatar
Ern
The closer the 2 big nuts are the tighter it is I assume. There is only like 1 thread there, 1 more thread and theyll touch and I think thats 10mm which is the stiffest setting. Its all snug and tight too. I dont get it.
Old May 15, 2006 | 05:51 AM
ReMz's Avatar
Any ideas?
=O
???? strange
Old May 15, 2006 | 06:03 AM
cvenom2122's Avatar
Thumbs up
mabe the wider tires? your getting better grip, what kinda tires you using?
buy stage 2 and youll have enough power to combat wheel hop for wheel spin
Old May 15, 2006 | 07:20 AM
06blackg85ss's Avatar
gettin the same problem here.... if I launch at higher rpms it just spins them ... no hop... at lower rpms though I still get hop
Old May 15, 2006 | 08:03 AM
Saki XL's Avatar
??? That's confusing... Is there any way possible you could have the TD on backwards? Damn, I hope I don't run into this problem...
Old May 15, 2006 | 08:10 AM
snobird's Avatar
maybe you have a bunny rabbit in your car lower your tire pressure to about 29 psi
Old May 15, 2006 | 09:34 AM
Ern's Avatar
Ern
The tires im using are in my sig. Kuhmo Ecstas spts. I was thinking the same thing about them being a wider tire. I also thought about lowering my psi but wtih my stage 1 on the way with my 3.0 pulley, i think itll take care of it.
Old May 21, 2006 | 05:00 PM
Badmunky's Avatar
Well befor stage 2 I had no wheel hop with just tires rims and the ZZp motor mount.
After stage 2 I have massive wheel hop agen.
I found that runing my tires at 46PSI with nitrogen insted of air gave me more grip then I had at 32psi with air.
As a resalt of geting more traction my clutch now slips. When I put my winter tires on I have no clutch slip and no traction ether.
Im runing with the winter tires on for now.
Later.
Old May 22, 2006 | 12:40 AM
ninja44's Avatar
Control arm bushings and GOOD struts are the only way to solve wheel hop. Motor mounts have nothing to do with wheel hop. The torque dampner only makes the wheel hop less violent.
Old May 22, 2006 | 03:54 AM
ReMz's Avatar
..... motor mounts have nothing to do with wheel hop.... ? and your last sentence is not contradictory at all...... .....
i dont even need to say anything and i rest my case
Old May 22, 2006 | 04:08 AM
Beck's Avatar
think he meant to say torque dampners have nothing to do with wheel hop lol
Old May 23, 2006 | 04:07 AM
ReMz's Avatar
haha...
he would still be VERY incorrect tho
Old May 23, 2006 | 04:35 AM
Brian MP5T's Avatar
Old May 23, 2006 | 08:08 AM
BLKSS's Avatar
Wheel hop is bad! Stage 2 its worst even. I couldnt get one take off at the races last week without hopping. No way that thing works its just too much. It has to be our wheels.
Old May 23, 2006 | 09:27 AM
ninja44's Avatar
People who believe that torque dampners solve wheel hop are misinformed. You buy a dampner to minimize motor movement not to stop wheel hop. The wheel hop will still occur with just a dampner it just makes it less violent as it occurs. As I said above, wheel hop will still happen but obviously the blows a softened due the motor not slamming around.
Old May 23, 2006 | 09:49 AM
Asphalt Assault's Avatar
He is absoulutely right. the purchase you made is going to help. with the power we had previously it was enough.
What is wheel hop. well it is the tire twisiting underload and traction to a point that is springs because the tire energy overcomes the spring and shock absorber. the movement of the engine just multiply's this affect. I dont know for sure but I bet LSD would help as well.
so what do you do? find someone who has a good setup. have you talked to someone with EIBACKS AND POLY URETHANE BUSHINGS control arm bushings? Just a guess that these two things with wider or even taller tires will improve things. Find someone with 255/60 r16 on there car. what results do they have.
bottom line i know what causes it and if I have a solution you bet I will post it here. good luck in your guest. you have made a good purchase by the way. you have just upt the ante that is all.
But what do I know.... I am a junior member. what a title!
Old May 23, 2006 | 10:27 AM
Cynic/Torque Forward's Avatar
Non Authorized / Non-Supporting
I'm running stage 2 with a full set of urethane motor mounts and a single torque brace right now (been too lazy to get under the car and install my other one.) I haven't had any problems with wheel hop at low or high speed.
The fact is that the more HP you dump into this car, the more you're going to have to dump into other parts such as motor mounts, control arm bushings, struts, etc... For the power levels we're achieving now, I think it's safe to say that you don't have to go overboard with things. Motor mounts, bushings, and/or a torque brace should suffice.
If you're running a stage kit and only a torque brace I would highly recommend upping the ante a little bit and adding a little bit more. They definitely help but as people have mentioned they are not the end all to your problems with wheel hop. Likewise, those of you that have bought the ZZP top mount are putting more bracing in the same area that your torque brace is while the other 3 are flopping around like a wet noodle. Good numbers are more than the amount of HP you're putting to the ground.
Old May 27, 2006 | 05:28 PM
Badmunky's Avatar
Ill be runing the following parts as soon as the trans mounts and CABs come it for wheel hop.
1: ZZP old style uper motor mount. (They have a new stiffer one that is more money but works beter. It dos make more vibes though)
2: 235 / 40 / 18 BFG KDW2s.
3: 18X7.5 wheels that are about 4lb lighter then stock each.
4: Intense Trans mounts (Not here yet)
5: JBP CABs (Also not here yet)
6: Eibach pro kit springs. (Have not ordered them yet) "Im off work for a few days do to a broken truck so there going to have to wait a few more weeks"
I think that all that should help me get off the line alot beter and get rid of 100% of my wheel hop on the street and the track.
Later
fslick
Feb 12, 2009 02:03 PM
SprChrg4Life
Sep 13, 2008 10:02 PM
cobss187
Aug 6, 2006 05:11 PM
blackphoenix
Mar 3, 2006 10:34 AM
