Will the dealer give me trouble? PIC
Old Jan 20, 2010 | 10:00 PM
dubbleduecer's Avatar
Noticed oil leaking from what I guess is Valve Cover Gasket.? I have GM dealer installed stage 2 and exhaust, but I have a generic Cold Air Intake that I put on about 20,000 miles ago. This is a new problem by the way. So im wondering if the dealer will give me troubles about doing warranty work because of the CAI? I dont have the original air filter system other wise I'd just throw that back on.. So im looking for some advice and I guess if anyone has experience with this should I buy a stock filter to put on before I take it to the dealer?
Old Jan 20, 2010 | 10:02 PM
tREBs's Avatar
They shouldnt, the CAI will really do nothing to cause this...
if they give you any BS bring up the Magnusson moss act...
they have to prove your aftermarket part DIRECTLY caused the damage.
Old Jan 20, 2010 | 10:05 PM
KillerBee's Avatar
X2 the man is on point!
Old Jan 20, 2010 | 10:15 PM
Sounds good thanks for the advice. Also, how pressing of an issue is this? I have a trip planned for tomorrow that has be driving 2 hours and I wont be back until Sunday. Should I try to reschedule or will this be ok to drive with?
Old Jan 20, 2010 | 10:19 PM
Caligula's Avatar
I doubt they would give you any trouble at the dealer.
Old Jan 20, 2010 | 10:21 PM
OriGinaL Condo's Avatar
I'd never drive the car with oil leaking (except maybe to the dealer if they were close by). Especially not a 2 hour trip.
Old Jan 20, 2010 | 10:24 PM
jsscooby's Avatar
I dont see any trouble.
Old Jan 20, 2010 | 10:27 PM
PRND3L's Avatar
thats seepage, not leakage.
Old Jan 20, 2010 | 10:30 PM
Seepage being the lesser of the two evils?
Old Jan 20, 2010 | 10:32 PM
BLAZIN07SS's Avatar
I'm too JDM for you
my car has been doing that for the past 30,000 miles. lol i finally got a new valve cover gasket for it to throw on when i put my painted valve cover on
Old Jan 20, 2010 | 10:33 PM
tREBs's Avatar
like mentioned that is "seepage" you are losing very little oil, just to be safe, before you set out on your trip top up your oil level. Bring an extra quart with you and check it after an hour of driving.
You will be fine
Old Jan 20, 2010 | 10:41 PM
exiged's Avatar
hopefully you just need a new gasket (unless there's something your not telling us. I'm not really sure what would cause that.) Which is a very easy R & R
Old Jan 20, 2010 | 10:43 PM
i may be not telling you something, but its because I dont know anything else.. Car is running fine, and its like 10 degrees if that matters.
Old Jan 20, 2010 | 10:49 PM
Silver Bullet's Avatar
did you try to snug it down a bit and also have you checked the pcv valve that can make oil start blowin out weird places if its stuck
Old Jan 20, 2010 | 11:01 PM
nicksredline's Avatar
as stated not a big issue lol mine leaked onto my manifold untill i just got tired of the smell of burning oil so i replaced the gasket and while i was at it i replaced the manifold with a header dp combo go me lol. top off the oil before and on the way back and ule be fine.
PS: DONT TRY TO FIX IT UR SELF if u break a bolt off or crack the valve cover or somethin stupid that will be ur fault lol DONT and i say DONT try and fix it just bring it in and get ur gasket replaced... my valve cover was warped when i first got my car so posably that happened to ur car.. not sure how there is not that much heat up there.if they see that u have tryed to do somethin there it will be blamed on u
Old Jan 24, 2010 | 10:41 AM
kretty's Avatar
They won't do anything until its at the drip stage. I have the same problem... Has to be worse than that.
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
