Dyno Results Dyno pictures, videos and dyno results.
LNF Dyno
Old Jun 7, 2014 | 10:22 AM
Terminator2's Avatar
Originally Posted by CudaJoe
Im actually considering a retune for my car because its kind of an off on switch now. Theres no happy medium where I can hold a partial throttle without the boost swinging from 14psi- 20 psi.... Cars fast at 100% throttle but I think I want something that will feel more like something from factory, meaning I can hold the throttle and at any percent (10%, 20%, 30%, 40%,etc...) and it wont get jerky on me
DALs, MALT and WG duty cycle need to be reworked. It is easy to have one that drives just like or even better than stock and when you nail it it goes like hell. I had mine like a light switch for a while and while it was fun doing rolling burnouts past people at only 50% pedal I got tired of it after a while and ended up making mine smoother than stock until right around wide open pedal. I almost always tune them such that you can hold any boost level you want at a given pedal so 50% pedal will hold 12 psi flat no swinging up with no change in pedal.
Old Jun 7, 2014 | 08:21 PM
Originally Posted by sstcsfsd
Alright, Well i made a few passes May 16, at Thunder Valley in Marion SD. Need some stickier tires, and trans mounts installed. The kumho ecsta 4x all seasons aren't the best for this. Wheel spin, and wheel hop, through 1st and 2nd gear. Best run was a 14.0 at 106. My 60' didn't read correctly, but i was averaged 2.4 60 foot on my other passes.
You gained only 3 MPH vs the stock tune on the same track which is not very good for an LNF. Most I have done on 91 octane have gained at least twice that many MPH vs stock. One went from 100 mph traps stock to 109 mph same track.
Old Jun 7, 2014 | 08:39 PM
sstcsfsd's Avatar
I had a lot of runs at that track that wouldnt break 100. 103 was the best run I managed at that track on stock tune, compared to first run tuned. I know its not a record breaking 91 octane tune.
Old Jun 22, 2014 | 11:37 AM
sstcsfsd's Avatar
I ran again Friday night, with rotated Tran mounts installed. It was hot and humid, but traction was better. Ran a 13.7 at 109. Intake air temps were around 130* at the starting line. If I get hp tuners, maybe somebody can look at the tune to see where it could be improved?
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
maliki778
Oct 1, 2015 07:39 PM
patooyee
Oct 1, 2015 01:07 PM
